vitara solid axle build
hows it im solid axle swapping my vitara at the mo so thought id share some pics
using a vitara rear axle up front with sj413 swivels and hubs (so i keep my stud pattern and brakes fit on still )
staying with vitara head as its a matching ratio and cheap not like hilux etc
new to posting pics here so bare with me
poor little suzuki
Re: vitara solid axle build
diff all centred up and made to suit the job as in offset of the head etc
swivels are just tacked in untill mounted on the radius arms thenn caster can be sorted when its at ride height
poor little suzuki
have slipped the 413 axle housing into the vitara housing by 80mm and will end up braced as well
poor little suzuki
got these cool shocks for it as well cant wait to set it up and use it
foa 12 inch travel
foa 12 inch travel
poor little suzuki
next up is sawing the factory trailing arm mounts off a poor un suspecting pajero for the trailing arms im planning on running
i was going to make my own at the chassis end but have herd of people punching the arms through brackets because there wasnt any support on the bush at the piviot end
heres a pic of the trailing arms
poor little suzuki
that's pretty resourceful. Well done. Will it be certed, or a trailer truck?
- Crawlerer79
Looks good! Very interested to see how you front axle set up works out, what do you plan on doing for axle shafts?
'Lando' - 1994 V8 Disco
Looking good so far, often wondered if it could be done.
- catalystracing
Looking good Greg
BlakeNZ wrote:that's pretty resourceful. Well done. Will it be certed, or a trailer truck?
just a trailer queen wof ran out a few days ago haha was driving up untill i ripped apart
poor little suzuki
Crawlerer79 wrote:Looks good! Very interested to see how you front axle set up works out, what do you plan on doing for axle shafts?
going to get a locall company to cut soem shafts for me they did my last set when i made the same axle
poor little suzuki
so been a few days since i posted here .... week or so haha
went and sawed the factory mounts off a pajero chassis for the trailing arms what a arrrssseeee of a job lol
cleaned them up and fitted them onto the chassis where i needed them i wasnt sure of placement as in do i run them on the under side or out side but i went with out side so far so good .... fingers crossed
made a plate to beef up the chassis rail at the front as chassis was only made of 2mm so ran some 3mm down it to make it stronger you cant see in the pic but i have drilled a large hole through the plate and secured the plate in the middle also so plate is fully welded on the edge and also in the middle
went to the scrappys today and got some heavy wall pipe for the steeering shafts that are now longer so have sorted that as well today
i allways go for the paint it when its together method and it allways looks crap and cheap so i buffed the diff head down today primed it and brush painted it with a couple coats of blaaaaaaccckkk my favourite colour haha
ended up fully welding the brackets and priming around the brackets and the parts of the housing i was finnished with
yet to come is the panhard mounts and the shaft it self i was planning on running a pajero factory panhard but i think the bushes will bind and steal some travel/ flex
ill dump a hole heap of pics here
not bad for a young bugger in a cramped single garage i reckon haha quite stoked how its coming along
poor little suzuki
all the pics didnt load grrr sorry if theres double ups
Greg
Greg
poor little suzuki
got the truck together enough to drive it today after making the panhard brackets and making what may be the most piece of over kill panhard for a suzuki haha i ended up going with a cat1 size tractor link (for using impliments behind tractors ) they use a very robust rose joint / rod end so i have sorted that mounted it heres a flex shot i think i need softer springs yet
poor little suzuki
Looking good man. Bring on the axles shafts
right so have been in touch with the axle man and hes giving my housing back on friday so i can fit new bearings and seals through it and finnish up the welding etc
heres some pics i have since plumbed in my fiddle brake to the front
pic of my cv rings fitted to factory birfeild cvs
let me know what ya think
greg
greg
poor little suzuki
Looks awesome Greg, loving your ingenuity. The CV ring is a good idea!
so while im waiting for axles to be done im getting some other mods done
used rivnuts for the first time today pretty cool things !
made these brackets from some old alloy i had in the back shed and did some work on another suzuki
i know the bolts are ugly cap screws to come
also did the 110 amp alt mod and threw new belts at it while it was apart
poor little suzuki
- catalystracing
Did more than a bit of work on my zook
Rear lokka fitted, 30mm lift springs in the rear, 50mm in the front, front steel diff fitted, top hat flip, manual hubs, oh and a sneaky lil suspension mod
All done in about 8 hrs including a test run
Thanks for the help, love working with ya
Cheers, Paul.
Cheers, Paul.
was grouse hanging out !!!
got the truck out side washed it did right bump stop and limit strap left side bump stop and limit strap to go and a rough wheel alignment
poor little suzuki
so got a bit done did the rear end while i was waiting
shaved the bottom off the diff ,added diff trusses mainly due to having them laying round for a 413 so made them fit
added discs and vr4 galant calipers
used a boc locker in the rear and installed it and repositioned the shocks as well
added a fiddle brake set up as well got this from e bay and mainly went with this design to save space in a tight cab
and man what a bastard to bleed up !!! took 3 litres of fluid and a lot of time and swearing !!!
sorted now
few parts to tidy up then waiting on axles
sorted now
poor little suzuki
axles back and fitted up all is well lost a bit of huff on the project and want something turn key fun ! so this is up for sale at the mo see what kind of hits i get
5k truck
live rego
crawler gears
33s silvys
flash cvs and axles
discs all round fiddles
ute chop
welded rear
12 inch travel foa coil overs
slotted rotors up front
1600 with cambelt water pump clutch etc done last few months
extractors and 2 inch exhaust
steel snorkle
bar work
on board air
9500 lb runva literally done 4 pulls since new
dual batteries
100 amp falcon alt mod
drive flanges for front
comes with spares and bits and bobs
extra 1500 you can have the trailer for it too new wof 1 yrs rego comercial tyres ... i did how ever break the tail light on it picking up a comodore eww yucky hahaha
located kapiti coast wellington
0272012916
happy to negioate price
5k truck
live rego
crawler gears
33s silvys
flash cvs and axles
ute chop
welded rear
steel snorkle
bar work
on board air
dual batteries
0272012916
poor little suzuki
since my last post ive decided i should grow a pair and keep the bastard truck haha
so today i fitted up the axles and fitted some sweet interior lights ! 60mm square led work lights its like day time in there !
ordered a air locker ... cos you know nothing like a freshly imported part to re ignite the drive to finnish the build !
also collected some auto trans parts so i can convert it to auto !
one so the mrs can have a drive ! two i love having a park position knowing there is a steel pin locking you truck in place is allways nice !
and 3 i loose omentum between 1st and 2nd and can create wheel spin and make hill starts a head ache so auto should solve that ive chosen the 4 speed ecu controlled unit so i can later on make a manual controll computer for it when i feel all the creases are ironed out
also picked up some spare front guards as they are just a consumable item
not sure if anyones even reading these posts so flick a comment if you are
poor little suzuki
1kz_surf wrote:not sure if anyones even reading these posts so flick a comment if you are
yeah bro, I want to see it in action.
- Crawlerer79
I sure am watching! Loving the build, and stoked to see you're gonna finish it!
v8 tj...luvs the gas......
oh wow cool to see !!
so boys this week some goodies arrived!
we got a air locker for the front
a wheel bearing kit
and a set of 10 inch travel bilsteins for the rear
plan this weekend work permiting ... front cover on front diff welded on and a final check of the hole set up for bolts and wheel alignment
then back into bleeding the brakes
got a day booked on the 14th to hoon it
a wheel bearing kit
poor little suzuki
so another weekend is here !
i ordered some mean 10 inch travel bilstein shocks from 4wdstuff gret guys btw! (shameless plug there !)
fitted them up yesterday used the modified mount i had made on the diff housing earlier andc mr suzuki the legend put a crossmember right where i needed one so drilled through that 100mm off centre and ended up using honda accord 97 ish 2.2l front springs in it they are damn close to being grouse ! soft enough that with all my junk on the tray it dosent loose too much height but still a long ass spring !!!
today should see the airlocker being installed into my spare diff head
and hopefully my gearbox in the old tow rig re installed and sold welll fingers crossed !
will post pics of the tre airlocker and install when i do it
heres some pics for ya troubles
subaru seats from a subaru outback
the front drive flanges
rear end
and also my tray i want to change but not sure on design yet
rear end
poor little suzuki
Users browsing this forum: No registered users and 17 guests
