Pajero rear diff lock problems
wisard2
Postby wisard2 » Thu Apr 07, 2011 3:48 pm
Having problems with the factory rear diff lock not engaging on my 1992 swb 3.0 litre V6 Pajero.
Might have to pull the diff to bits to find what the problem is and fix.
Does anyone have a pdf manual covering the rear diff they can please email me?
Thanks.
92 swb Pajero ute. 3 litre V6 manual. 33" Mud wranglers, Diff breathers, Snorkle, 9500lbs electric winch, Rear diff lock, CB & PRS radio's.
NJV6
Re: Pajero rear diff lock problems
Postby NJV6 » Thu Apr 07, 2011 4:29 pm
Is the compressor running when you switch it on?
does the light on the dash go solid when you lock the diff?
wisard2
Postby wisard2 » Thu Apr 07, 2011 9:00 pm
I have checked the compressor, and also taken off the rubber tubing where it connects to the diff inlet and it is pumping air fine.
The light does go solid on showing diff to be locked on the dash.
I have tested the drive on a soft bank and only 1 rear wheel is turning, as it was during our last trip on Sunday.
NJV6
Postby NJV6 » Fri Apr 08, 2011 12:34 am
Have you changed the oil? I think you will find if the light is going solid the diff is locking fine but there are no longer any teeth on it, it is a known weak point on the locker, this is what came out in my diff oil.....
wisard2
Postby wisard2 » Fri Apr 08, 2011 4:20 am
Mmmmm, I suspected as much. Will drain the diff oil tomorrow and see what happens. Thanks for that.
Are the parts still available to repair the diff?
wisard2
Postby wisard2 » Fri Apr 08, 2011 4:41 am
I asked a question about a factory lock diff on TM, which is below, and the guys answer. Will this diff with same ratios fit my Pajero?
Hi, do you have a rear diff with factory locker for a 1992 3.0 litre V6 manual? Trans/axle code is; V5MT1 4875.
Hi, I have a diff out of a 4D56 2.5 turbo diesel which is also 4875.
NJV6
Postby NJV6 » Fri Apr 08, 2011 8:18 am
Yep, that diff will bolt straight in.
As for parts, I didn't even try due to price but I seem to recall only being able to buy the whole diff centre and for that price you'd get an arb.
Landy Rover
Postby Landy Rover » Fri Apr 08, 2011 12:59 pm
wisard2 wrote:Mmmmm, I suspected as much. Will drain the diff oil tomorrow and see what happens. Thanks for that.
Must of broke when we heard all that revving in the loop track ah Ryan :lol: :lol: :lol: :lol:
S3 Rover truck cab, injected 186, Sals rear,Toyota P/steer, Safari disc brakes front, R/Rover D/brakes rear, 9500 winch,twin optima batts, roll bar, Disco seats, 33" JTs, scene lamps, onboard air, Front ARB locker.
Return to “Mitsubishi”
Users browsing this forum: No registered users and 9 guests
