L200 4x4 manual to auto conversion
MSTA57
Postby MSTA57 » Sat Feb 07, 2015 1:09 pm
Hi all,
I have a question about converting a 1991 L200 turbo diesel 4x4 from a manual gear box to a autmatic transmission,
is it able to be done using a trans out of another mitsubishi 4x4 vehicle and keep it 4wd,
or would i have to just use a RWD transmission and leave it at that,
The reason I need it made automatic is due to being mainly in a wheelchair and can only drive auto vehicles.
the vehicle i'm asking about for the conversion is because its for free,
all help is kindly appreciated,
Thank you
Crash bandicoot
Re: L200 4x4 manual to auto conversion
Postby Crash bandicoot » Sat Feb 07, 2015 2:01 pm
4d56 engine correct? pajero auto from same era should bolt right in
just be aware that the auto may not get lock up and overdrive without the inputs from the tps and speed sensor on manual engine so make sure you get that too
MSTA57
Postby MSTA57 » Sat Aug 15, 2015 3:35 pm
Ok cool as. Thanks for that
Return to “Mitsubishi”
