pajero exceed no power , your thoughts?
basics
Postby basics » Sat Nov 19, 2016 12:30 pm
first noticed the check engine light came on this morning as i got on the on ramp and it stayed on for only 2-4 seconds so i carried on.
then heading up a really long steep hill, at high way speeds i lost most of my power, it wouldnt rev past 3000rmp (3.5petrol) and slowed down to about 40kph.
all the fluids are fine,
had the cam belt and water pump done less than 1000km ago
im thinking its the fuel filter as it only happens when i mash the peddal. it cruises nicely on the open road but if i come to a red light and try get going again, goes good unless i go past about 2700RPM.
any ideas?
99 pajero exceed 3.2
derk
Re: pajero exceed no power , your thoughts?
Postby derk » Sat Nov 19, 2016 12:45 pm
limp mode?
muddy
Postby muddy » Sat Nov 19, 2016 12:57 pm
My brother has similar issues with his after the Christchurch earthquakes. Refuelling during mild aftershocks and sediment in the service station fuel tanks caused huge problems. Cost him a couple of grand to replace fuel filters and injectors, and flush the whole fuel system....
basics
Postby basics » Sat Nov 19, 2016 12:59 pm
derk wrote:limp mode?
yeh feels like it, but you dont really notice it on the flats untill you accelerate hard or go up hills.
the check engine light is only on when im hard on the gas, and not really hard at all
basics
Postby basics » Sat Nov 19, 2016 1:00 pm
muddy wrote:My brother has similar issues with his after the Christchurch earthquakes. Refuelling during mild aftershocks and sediment in the service station fuel tanks caused huge problems. Cost him a couple of grand to replace fuel filters and injectors, and flush the whole fuel system....
fuel crossed my mind, the pevious owner only ever used 91, and ive filled it up 3 times since ive owned it, agaon with 91
maybe i should be using a higher grade fuel
sirLachlan
Postby sirLachlan » Sat Nov 19, 2016 4:10 pm
Here's a tip . Get the codes out of it and see why the engine light was on
basics
Postby basics » Sat Nov 19, 2016 4:43 pm
sirLachlan wrote:Here's a tip . Get the codes out of it and see why the engine light was on
ill drop it off on monday morning to see what they say about it.
Crash bandicoot
Postby Crash bandicoot » Sat Nov 19, 2016 5:27 pm
Fuel or maf.
basics
Postby basics » Mon Nov 21, 2016 3:20 pm
I got the call i didnt want from the mechanic. Its one of the injectors thats shat itself. :cry:
basics
Postby basics » Wed Nov 23, 2016 6:14 pm
:oops: Bit of help here gurus.maybe a dumb question...
Found these injectors online
http://m.ebay.com.au/itm/6-FUEL-INJECTO ... Ciid%253A3
The only differnce is my pajero is an MN. These injectors say for n NL.
Same engine as mine so will this make any difference?
My engine is the 6G74 and the old injwctors are yellow so should be the right ones. Right???
Thanks
NJV6
Postby NJV6 » Wed Nov 23, 2016 6:18 pm
Yours is the NM (as opposed to the MN you typed) but like you I'd be very certain they are the same, assuming yours in not the GDi motor. But having clicked on the link I might not be so sure?? Try this one??
http://www.ebay.com.au/itm/FUEL-INJECTO ... 2299473334
basics
Postby basics » Wed Nov 23, 2016 7:06 pm
Hhmmm
The different colors mean different specs id imagine? Since my stuffed ones are yellow i should stick with yellow i guess?
And yeh mine is the GDI
https://www.carjam.co.nz/car/?plate=Frk530
juz
Postby juz » Wed Nov 23, 2016 10:56 pm
My diesel Triton did similar thing, ended up being a sensor. Maf/ boost... can't remember but was no biggy.
cornflake
Postby cornflake » Thu Nov 24, 2016 3:55 pm
im guessing it is v6 petrol y not just go up to pick a part and have a look at a diamante or some thing might have the same injectors up there
Crash bandicoot
Postby Crash bandicoot » Thu Nov 24, 2016 6:00 pm
Diamante does have same injectors. I have diamante injectors in my 1995 6g72
dvk-kp
Postby dvk-kp » Thu Nov 24, 2016 6:20 pm
Crash bandicoot wrote:Diamante does have same injectors. I have diamante injectors in my 1995 6g72
Are they Bigger/better or just an easy to find replacement?
cornflake
Postby cornflake » Fri Nov 25, 2016 3:54 pm
yip probably get all 6 injectors from pick a part for probably price of 1 i love that place
Crash bandicoot
Postby Crash bandicoot » Fri Nov 25, 2016 4:31 pm
More common...... The price goes up when you mention its for a 4wd.
basics
Postby basics » Wed Dec 07, 2016 4:21 pm
ended up finding them on ebay,6 remanufactured for under 400 bucks
Return to “Mitsubishi”
Users browsing this forum: No registered users and 11 guests
