Can you help?
BogBoy
Can you help?
Postby BogBoy » Tue Nov 06, 2012 8:58 pm
Ok so I need to know the name of the bar that bolts to the back of the rear axle to the body..
I need to get a adjustable one as my axle is 15 mm over to the drivers side after the new +2" springs were put in....
OR can you cut the factory item and make it adjustable? IE weld and fit adjuster
nismo26
Re: Can you help?
Postby nismo26 » Tue Nov 06, 2012 9:00 pm
Panhard? if it is you can make a drop bracket or make it longer I cut mine in half and used a bigger bit of pipe over it, doesn't have to be adjustable.
BogBoy
Re: Can you help?
Postby BogBoy » Tue Nov 06, 2012 9:07 pm
nismo26 wrote:Panhard? if it is you can make a drop bracket or make it longer I cut mine in half and used a bigger bit of pipe over it, doesn't have to be adjustable.
Yea I thought is was called the pan hard rod but appco looked at me side ways...
So cut it and weld it? just make sure I get the right length first?
ArvinSlayer
Re: Can you help?
Postby ArvinSlayer » Wed Nov 07, 2012 8:26 am
grab a manual, if i am not wrong ures is a WD21 isnt it? Then u will know exactly what it is, i will see if i can scan my haynes manual page and pt it on later
Peace
Arvin
DEATH_INC
Re: Can you help?
Postby DEATH_INC » Wed Nov 07, 2012 8:28 am
Where are you?
Dirtydog
Re: Can you help?
Postby Dirtydog » Wed Nov 07, 2012 8:47 am
they are called panhards but ive heard people call them track bars and all sorts of funny names.
theres some good ones on 4wdbits.co.nz which are adjustable, great for if you lift/drop the vehicle etc.
but i think making the mount lower on the chassis would be alot better because it keeps the rod more parallel to the axle.
4WDbits
Re: Can you help?
Postby 4WDbits » Wed Nov 07, 2012 9:03 am
Panhard or panard.
The closer to horizontal at static ride height the better. The bigger the angle the worse the handling at speed.
keepwalkn
Re: Can you help?
Postby keepwalkn » Wed Nov 07, 2012 1:13 pm
Rumour has it you can use a Toyota 80 series panhard in it's place...You may be able to source an adjustable and just change the bushes.
Would be worth looking into!
DEATH_INC
Re: Can you help?
Postby DEATH_INC » Wed Nov 07, 2012 1:57 pm
Back when I was at Autolign we modded an adjustable commodore one to suit a surf.
BogBoy
Re: Can you help?
Postby BogBoy » Sun Nov 11, 2012 6:11 pm
4WDbits wrote:Panhard or panard.
So might pay to lower the mounting point on the body?
tweake
Re: Can you help?
Postby tweake » Sun Nov 11, 2012 6:17 pm
yes if you can.
commonly done in the surfs.
the more angle you have the more the axle gets pushed sideways when the suspension moves up/down.
passengerpete
Re: Can you help?
Postby passengerpete » Sun Nov 11, 2012 6:25 pm
tom did this too mine. very well priced and what a difference.
DEATH_INC
Re: Can you help?
Postby DEATH_INC » Mon Nov 12, 2012 10:10 am
passengerpete wrote:tom did this too mine. very well priced and what a difference.
That's a pretty serious looking bracket, as usual from Tom.
I did the usual bolt in drop box that goes inside on mine, with a brace to the other side...but yup, I was surprised how much difference it made.
BogBoy
Re: Can you help?
Postby BogBoy » Sun Nov 18, 2012 10:44 am
Can he make another one? Weld on or bolt on?
Users browsing this forum: Majestic-12 [Bot] and 5 guests
