its a 1995 terrano auto d21 td27t this motor has a black rocket cover
open to any ideas?
any ideas on making a td27t go harder
- Crash bandicoot
Re: any ideas on making a td27t go harder
intercooler/ egr removal
Big dump pipe. Bigger turbo if wanting over 20psi
Custom exhaust manifold. Standard ones look like made from lego.
Crash bandicoot wrote:intercooler/ egr removal
Hey can i ask what the egr is ???
Talk to wax on here if you really want to get sitloads of power out of it,
egr is an exhaust gas recirculation/recylcling sytem.
Is a pipe that runs from your exhaust manifold to your intake manifold.
If ya want a rundown on what I've done to mine.... http://www.nissanpathfinders.net/forum/ ... y-td-27-t/
Bro, just pour concrete all over it and leave it in the sun for a few hours, it will go mean hard fast!!
- Driver/Navigator
im running 15psi with a intercooler and its still abit slow
run a bit more and turn fuel up more.
shes not overfueling till shes rolling coal....
Any tips for the TD27's bigger brother? The QD32ETi ? I guess you are limited with this one since the fuel and I believe boost too is ECU controlled.
Think I've pretty much settled on a Regulus RS-R as a daily drive and to occasionally tow the mud rig around.
convert to mechanical pump and turn fuel up
otherwise what are you worried about?
not much you would want to improve on the qd32 with turbo and intercooler.
unless you want to get into a bigger turbo etc ($$$)
use a na qd32 it has an 11mm pump and the td27 manifold will bolt on as well.
Or use a qd32 and make your own manifold
Users browsing this forum: No registered users and 11 guests
