wheel nuts?
Posted: Sun Jan 19, 2014 12:57 pm
i have a set of surf alloy wheels for my 90 terrano and cant source some wheel nuts to fit i have a full set of patrol alloy wheel nuts but the diameter of the shank is rubbing the stud hole of the surf rims iv noticed a few guys on here with the surf wheels on what nits did you use?? they grind the stud hole and are hard to het off even with a rattle gun, also any of you use hub rings i was quoated $50.00 a peice because of the odd sizing help?
