lsd terrano
- mr terrano
- Bush Crasher
lsd terrano
hi guys im looking for a lsd in my v6 terrano dossent look like mine has one in i its a 1991 v6 terrano now i have found one and it all looks good its out of a desil will this matter at all the ratio is 4.625 any help would be good asap
- Crash bandicoot
- Crash bandicoot
Re: lsd terrano
Just off the top of my head i think your original will be 4.375. As long as the carrier bearings are the same you can put your ring gear on the LSD head and bolt it back in no problem but if not, if you can get your hands on the diesel front diff to would be a goer and just swap both the front diff and rear pinion/head out for the 4.625
Re: lsd terrano
x2
that motherf***r should go straight in
- mr terrano
- Bush Crasher
Re: lsd terrano
Crash bandicoot wrote:Just off the top of my head i think your original will be 4.375. As long as the carrier bearings are the same you can put your ring gear on the LSD head and bolt it back in no problem but if not, if you can get your hands on the diesel front diff to would be a goer and just swap both the front diff and rear pinion/head out for the 4.625
CHEERS MATE
- mr terrano
- Bush Crasher
Re: lsd terrano
lax2wlg wrote:x2
CHEERS BRO WAS HOPING TO JUST BOLT IT ON THERE AND AWAY U GO LOL
Re: lsd terrano
Sweet, V6 goes good with 4.6 gears
What crash is saying is that the 4.6 LSD diff head will plug straight in but you'll need to regear the front diff to match. So you'd need to find an R200 front diff from another V6 model, build plate HG46.
Easier option is to bolt your 4.3 ring gear to the LSD carrier and install it back in your 4.3 housing.
If you have never done this, there is a method to keep the side bearing backlash settings intact.
Also when you disassemble the 4.6 take photos of the side bearing cap orientation, and also the SIDE BEARING RACES! Mark them with paint if you need to. Its critical that they are put back together in exactly the same way.
- mr terrano
- Bush Crasher
Re: lsd terrano
lax2wlg wrote:Sweet, V6 goes good with 4.6 gears
sounds like a mish ill do a lil resarch as i have no experance in diffs but always keen to learn good old kiwi attitude
- mr terrano
- Bush Crasher
Re: lsd terrano
also is there such thing as a lsd frond diff
Re: lsd terrano
What part of the country are you in? I have an R200 in 4.6 here that I wont be using now.
To get a front LSD you need to make one, get a C200 (rear of 4x4 Navara) LSD centre and fit it into your diff
- Crash bandicoot
Re: lsd terrano
mr terrano wrote:also is there such thing as a lsd frond diff
yep its the same diff used in the back of pretty much most turbo nissan rear wheel drive performance cars. both me and lax have r200 front lsd/ locker combo's
- mr terrano
- Bush Crasher
Re: lsd terrano
Crash bandicoot wrote:mr terrano wrote:also is there such thing as a lsd frond diff
is there any other info you could give me on the front lsd please im very intristed in doing this
Re: lsd terrano
Buy this the centre will fit into an R200 front
http://www.trademe.co.nz/motors/car-par ... 931408.htm
- Crash bandicoot
Re: lsd terrano
mr terrano wrote:Crash bandicoot wrote:mr terrano wrote:also is there such thing as a lsd frond diff
there is two ways you can do it. One is easier and requires less hunting around for the correct parts The other requires tracking down parts that are generally more expensive but stronger.
I suggest you use the search function here as it has been covered many times and comprehensively.
Re: lsd terrano
ChurchurDan wrote:Buy this the centre will fit into an R200 front
Yeah that one.
Probably most of these LSDs are old and worn out.
Gotta rebuild that puppy for maximum good times.
Re: lsd terrano
Or buy an R200 ARB locker that I have lying around
- mr terrano
- Bush Crasher
Re: lsd terrano
HG43 - Found on Pathfinders, V6 Hardbodies, and a few '99 Frontiers - H233B rear / R200 front, 4.375:1 gearing. On the 2000+ 33 spline axles, the HG43 has a 4.363 ratio, however this is not a common axle code on the later models.
here it says that i already have an r200 front diff
- mr terrano
- Bush Crasher
Re: lsd terrano
so just going to look for a 4.3 lsd for rear and make a lsd for front or just get air locker
Re: lsd terrano
You should buy Simon's (sibainmud) R200 airlocker for the front.
Its a genuine ARB, not some shithouse knockoff.
- mr terrano
- Bush Crasher
Re: lsd terrano
hey guys still looking asnyone got one?
- Crash bandicoot
Re: lsd terrano
mr terrano wrote:hey guys still looking asnyone got one?
yeah i know where there is a R200 airlocker, whats your budget?
Re: lsd terrano
Is this locker you know of still for sale?
Cheers Pete
Cheers Pete
Re: lsd terrano
i've PM'd you, CHCH pete.
Users browsing this forum: No registered users and 31 guests
