http://www.offroadexpress.kiwi/Forums/viewtopic.php?f=25&t=30767
I have a problem with the after-glow on my 93 terrano. Smokey as guck and missing after engine started.
First relay heats glows at full voltage before starting, second relay supposed to stay on at for 600 seconds once running, glow plugs at half voltage (unless above 20km/h or coolant above 50 deg C).
My first relay (glow) works correctly, the second relay (after-glow) switches on and off for about half a second, regardless of coolant temp or speed.
Bridged relay out and got correct half voltage at glow plugs. Must be the controller??
Anyone else had this problem?
Any ideas on a solution? (last resort manually switch this relay as I know I would always forget to switch it off)
