My safari diff lock???
dangerous
Postby dangerous » Tue Oct 20, 2015 6:38 pm
yeah well just picked a 92 up with the diff lock switch on the dash... turn it on and the light on the dash does not come on and it dosent seem to work...
How do these things work, electric, vacume??
Now having just crossed the river in 2wd it boged down spinning one wheel... NO LSD huh?
learn me nissan people, what do I need to do?
Lchundy
Re: My safari diff lock???
Postby Lchundy » Tue Oct 20, 2015 7:53 pm
There's a solenoid on firewall that the switch actuators
I know that they can fail
dangerous
Postby dangerous » Tue Oct 20, 2015 7:56 pm
good place to start, any one have a photo so i know were to look on the fire wall?
Lchundy
Postby Lchundy » Tue Oct 20, 2015 8:06 pm
Upper passengers side.
tuckertrucker
Postby tuckertrucker » Tue Oct 20, 2015 9:35 pm
Is it rear diff lock? The 92 safaris came out with LSD - and the LSD is pretty much the best in the business. Mine will try to bind up even on pavement. But if it has a locker the lsd wouldve come out wouldnt it? Id say go back to factory lsd, only really need a locker on the front which is open diff.
dangerous
Postby dangerous » Wed Oct 21, 2015 5:05 am
well im not sure thats why Im asking, im asuming its open frount and rear with rear lock opption...
got stuck in river shingle yesterday were my previous D40 navara hauled throu
J_Dub
Postby J_Dub » Wed Oct 21, 2015 5:36 am
If it has a diff lock switch then that's what it has, no lsd
mudtroll
Postby mudtroll » Wed Oct 21, 2015 6:31 am
Buy a Mac valve to replace the solenoids, or if you have on board air use that but very low pressure.
nuts
Location: somewhere arround westcoast offroading usually
Postby nuts » Wed Oct 21, 2015 9:42 am
also can use emissions solenoid as a repair ... thats how ive fixed that prob b4
dangerous
Postby dangerous » Wed Oct 21, 2015 7:20 pm
mudtroll wrote:Buy a Mac valve to replace the solenoids, or if you have on board air use that but very low pressure.
what is this mac valve?
Postby coxsy » Wed Oct 21, 2015 8:02 pm
a 24 v mac valve is sold by Mac valves ltd , one in onehunga Auckland
it's the block on pass. side above fuel filter,
about $106 rebuildable mines been on over 5 years now or more
89 safari, pto winch, 33x15 simexs. sliders,75mm lift . turbo
dangerous
Postby dangerous » Wed Oct 21, 2015 8:24 pm
thats a farking big turbo man, you compercating for something else... ok so googled the nissan part and looking at mine it has wiring, small pipe into 2 and a couple a large pipes, how does your mac valve work?
ps priced the nissan one today $600+ and ex nippo land
Postby coxsy » Wed Oct 21, 2015 8:43 pm
yes big turbo , no over boasting now 12 psi max, yes Nissan replacements aren't cheap, hense Mac Valves ,
first turbo system came from DSR where you are, it blew up , oil seal, Garrett this time :D
mudtroll
Postby mudtroll » Thu Oct 22, 2015 5:59 am
http://www.macvalves.co.nz/ 24Volt Mac valve part No 45A-AC1-DDAA-1BA get the waterproof mod 532F
charo249
Postby charo249 » Thu Oct 22, 2015 12:30 pm
Check all hoses and wires on the actuator (will be on the pumpkin of the rear diff) as these can get knocked off. Best to be stationary in 4wd low before engaging diff lock as well, then dash light will flash a couple of times then glow constantly when the diff has locked in.
tuckertrucker
Postby tuckertrucker » Fri Oct 23, 2015 8:28 am
Im probably just saying what everyone else is saying, but as said above, if it has a diff lock switch, then itll have an open diff with locker. So if youre spinning a wheel, then its unlocked meaning your problem is somewhere between the switch and the actuator.
Ive heard of a guy with an 80 replace the diff lock and rip out and rebuild the vacuum system before discovering the problem was the switch on the dash had tripped its fuse.
Postby coxsy » Fri Oct 23, 2015 3:35 pm
jack the rear diff in the air run the engine , try the switch rotate the wheels by hand [youtube][/youtube]soon find out if it's in or not one spins or both , done !
dangerous
Postby dangerous » Fri Oct 23, 2015 5:23 pm
coxsy wrote:jack the rear diff in the air run the engine , try the switch rotate the wheels by hand [youtube][/youtube]soon find out if it's in or not one spins or both , done !
ffs... why didnt i think of that.
tell me tho when you flick the switch should you not here a solenoid click or something?
Postby coxsy » Fri Oct 23, 2015 6:50 pm
maybe so, but the spin method works, :D ,weather permitting. this weekend
tuckertrucker
Postby tuckertrucker » Fri Oct 23, 2015 8:53 pm
Good to see you chose the safari by the way, I was reading your post asking about them. Good pick!!
dangerous
Postby dangerous » Sat Oct 24, 2015 9:01 am
tuckertrucker wrote:Good to see you chose the safari by the way, I was reading your post asking about them. Good pick!!
yeah but I got tucked.. ment to have 109k on it but were n tear shows more, windod not working as the diff lock, driving from picton to chch it regestered 38km in toll...
money I was going to spend on it with a lift and bar n winch will have to be spent repairing it... it does have a very nice turbo st up and its a manual
tuckertrucker
Postby tuckertrucker » Sat Oct 24, 2015 9:12 am
ouch :|
well at least you know when its all sorted that youll have a good truck!!!
the turbo and manual are a bonus too. These things love them turbos and imho manuals are better in every way :mrgreen:
Twodiffs
Postby Twodiffs » Sat Oct 24, 2015 3:24 pm
They sometimes have issues with the little plastic gears that link the trip meter to the speedo and to the small elec motor which provides the drive
electronically. It's not common but definitely not unheard of...i'm picking that's why the speedo didn't tick over all the time.
Probably just send it in to Parrotts if you want to keep the mileage legit and they will sort it....for 1 arm and your next child :? .
And x50 for what trucker said, despite someone suggesting that turboing an old td42 grain cutter is 'arguable' - they definitely do mate up very very well with a turbo. :mrgreen: .
dangerous
Postby dangerous » Sun Oct 25, 2015 9:18 am
coxsy wrote:maybe so, but the spin method works, :D ,weather permitting. this weekend
yes and no... with arse up in the air... neautral spin one wheel and easly hold the other, engine on flick the DL on and no differance, but if 4x4 inguaged there is some friction.
should the DL work in 2x4 or only if in 4x4?
Postby coxsy » Sun Oct 25, 2015 11:05 am
it should lock in, 2x4 , neutral , or 4x4 the diff is only connected by the driveshaft ,
operates independently
dangerous
Postby dangerous » Sun Dec 20, 2015 5:40 pm
well it was working now its failed... it wont switch on, but if I pull one of the outlet hoses off the solenoid it does...
can some one check with theres by pulling the two exit pipes off while engine is running and tell me by putting their finger over the solenoid pipes if one or two are sucking in the OFF position and the ON position, cheers ta
Postby coxsy » Sun Dec 20, 2015 5:58 pm
solenoid has died or failed take ya pick only 26 years old after all, :D
dangerous
Postby dangerous » Sun Jan 03, 2016 2:58 pm
bloody thing.... balls up over xmas ment I never got the mac valve, but just been away on the coast and the diff lock light on the dash keeps randomly coming on, lock is not inguaging, can i asume corectly that it can only be the wiring at the diff or switch thing in the diff that is at fault this time?
Postby coxsy » Sun Jan 03, 2016 3:03 pm
test the wiring with muitly metre see if it's a open circuit. or not
muddy
Postby muddy » Sun Jan 03, 2016 4:25 pm
Check for vacuum at the diff. There should be two hoses going into the diff. Vacuum on one to disengage the lock, and on the other to engage. If the vacuum doesn't swap hoses with the switch - then work back to a solenoid problem. If no vacuum on either, then either the solenoid or vacuum hoses further upstream. But the diaphragm on the diff is also known to fail, and can be tested by running a hose from a separate vacuum source to the diff and test on both lines - and if you're at the diff, you should hear it engage / disengage, but can also check by spinning the wheels
Return to “Nissan”
Users browsing this forum: No registered users and 6 guests
