anyone know the legalities of doing an open back ute chop?
have lwb low roof that needs the arse chopped off it
http://www.google.co.nz/imgres?imgurl=http://www.mudrhino.com.au/Images/ImageGallery/junk4.jpg&imgrefurl=http://www.mudrhino.com.au/ReadersVehicles.htm&h=600&w=800&tbnid=8IR8pvHL26SnTM:&docid=IeJGdnFthn6RhM&ei=ShJcVq7xFqXDmwWg_7CACg&tbm=isch&ved=0ahUKEwiuvt2w5rfJAhWl4aYKHaA_DKAQMwghKAYwBg&biw=1366&bih=657
something along these lines
safari ute chop
Re: safari ute chop
Legally, It will require low volume certification. Mine was done at katikati engineering by the previous owner. They've done an excellent job of the deck. Apparently the do a lot for forrestry, so they'd be a start.
Didn't deal so well with the gutters inside the roof and now have rust patches coming through. But on the whole, fairly happy.
Of course, practically, all that's needed is an angle grinder and a welder...
Edit: is it to be for ffroading only?
Re: safari ute chop
MihiT wrote:Legally, It will require low volume certification. Mine was done at katikati engineering by the previous owner. They've done an excellent job of the deck. Apparently the do a lot for forrestry, so they'd be a start.
Yep will definitely need a cert but not sure if I have to have a back wall or if I can just brace it and leave it open
Might just email a certifier and see what they think
- gary_in_nz
Re: safari ute chop
Any replies from the cert guys? thinking of doing something like this with a rust truck i have, whether its the roof chop our rear end chopped, still not sure.
Users browsing this forum: No registered users and 17 guests
