Hi Folks
My Dad has a 2010 Spanish Ti 450 pathfinder, and the battery is stuffed. The batt tray seems quite small for the place it's in, and it's too small to get a 305mm battery in. Whats the largest battery I can get in the thing or is there another tray that will fit?
Ta
Largest battery for R51 Pathfinder
- floatingkiwi
1999 KZN185W SSRG TJM T-15 Bar, Tigerz11 2speed winch, 2" EFS sus lift, 265-75R16 Engine guardian. Auberins EGT. LED light strips. weathertech cargo liner. Safari Snorkle SS145HF. Prado rad. Front and rear E-locker.
Re: Largest battery for R51 Pathfinder
R20 Spanish assembled mistral tray. I had 305x200 mm 8 cell 770cca batteries. One each side.
A 305mm battery is a 27 box size, so if that wont fit you will be stuck using a 24 box size. The grunt winner in that size is a red top optima at 1000cca. Bit pricey but very good batteries.
- floatingkiwi
I was thinking of trying one of the exide orbitals (supercharge brand). He will have a winch shortly too.
- floatingkiwi
Here we are again with My dad's 2010 pathfinder. The 4 yr old MF66 has died many times and tests badly now. What is the biggest sucker I can get in that size? Diff battery trays are not an option right now. Is there a dual batt kit? Seems no room for a second battery anywhere.
