Saf sprite steerng box
- mudlva
Ok fellas got a goodie here.
Twisted the sector shaft on my industructable steering box......
Now i know these are as rear as hens teeth so....
Does anybody know where i can get a replacment shaft from?
Or
If a shaft out of a small truck would fit?.
Or do i ditch it and go hydrulic steering?
This is the box. To dark to get photo of spline
Or
Re: Saf sprite steerng box
Is that the bigger of the 2 safari steering boxes?
Might know where one is
There is one for sale on trade me, but he wants ridiculous money for it.
Yea I'm using an 082, took ages to find it too. What did you actually twist on it?
- mudlva
Twodiffs wrote:Yea I'm using an 082, took ages to find it too. What did you actually twist on it?
Not to sure. Was doing a hard climb bouncing off banks etc.
Know i slid hard a couple of times. Failing that there were several times of bouncing off rocks and tree roots during the complete ran.
Either way its still twisted.
There was a chap on here a whilst back advertising a full hydro steer unit.
Anybody remember who it was??
Andy 79465? Think he has sold it though.
- mudlva
righto ive sent Andy a pm so if anybody knows him zap him a text on my behalf please.
so im heading down the rout of hydro steer. any pointers before i get the grinder out.
its fitting onto a y60 diff, i would like to mount it on the rear to assist in protection plus thats where the tie rods are. is that the best option?
what about a ram on the front of the diff doing push/pull onto the steering link mount?
also the chevy pump has been "modified". how do i work out flow/pressure fiqures and match the ram and steering box units ?
I'm looking at doing the same soon. Thinking rear the best option, slightly better protectored, existing mounting arms, front would need a mod on drivers side & panhard in the way. Cons hard to get the diff head out unless everything is un-boltable & I bend the rear tie rod more than the front, don't know if that's from hitting it or pressure on the wheels bending it.
I'll txt Andrew for you.
- mudlva
mudtroll wrote:I'm looking at doing the same soon. Thinking rear the best option, slightly better protectored, existing mounting arms, front would need a mod on drivers side & panhard in the way. Cons hard to get the diff head out unless everything is un-boltable & I bend the rear tie rod more than the front, don't know if that's from hitting it or pressure on the wheels bending it.
Cheers Rog.
Maybe we could look at a dual buy?
Dont know what fluid rate and pressure your pump deploys. Reasonably certain my chevy pump will cope.
Something to look at is a single v belt can only transfur around 4.5hp. The pump on 4wdbits is only a single belt so std pumps with a little tweeking should proform adaquately...
Fyi my pump will not operate on a single belt but with the double belts fitted i can turn lock to lock at idle on tarseal using just two fingers running my 36's at 12pd.
Never been able to do that in the previous 10+ yrs of v8 wheeling. Very impressed i am...
- Checkerhead
Mounting a ram on the front and leaving the tie rod in place is not ideal because it would use a single ended ram. You really want a double ended ram such that the piston surface area and bore volume is the same size for both directions. This will give you equal strength and speed steering in both directions.
I've never done it but Madaz has recently gone down this path a reckons you'd be hard pressed to get everything sorted for less than the price of a trail gear kit from either Warren (4wdbits.co.nz) or Tim (4wdstuff.co.nz). Also he was impressed by how much stock they each had on hand. Both are super helpful guys. I'd ring/email them and have a chat.
Other option is to go hydro assist , probably be easier to install behind the axle housing, just need to work out where to tap into the steering box hydraulic circuit.
Tim
Tim
I'll have a talk with you at Possum Tim
Im too looking at hydro steer on a dedicated offroad build using Y60 diff im about to start (I pickup diffs this week.)
Was also looking at rear mounting if pos rather than front to avoid the frontal rock impacts etc
Was about to look at who can supply locally else going direct to Trailgear site
- mudlva
Craydiver wrote:Im too looking at hydro steer on a dedicated offroad build using Y60 diff im about to start (I pickup diffs this week.)
Been speaking to warren and trail gear dont do y60 stuff. Its a case of using some t.g. stuff and fabbing to suit y60 or modfing y60 to suit t.g. either way mucking around will be involved
Yeah as Checkerhead said the stuff in the TrailGear kits that 4wdbits and 4wdstuff are doing seems pretty good quality, can be mounted up outta the way on a toyota diff.....
( not that that helps all you Datsun owners......... )
On those TrailGear kits they can supply whatever pulley you need, be it a single V or a multi rib
- Bush Crasher
The nissan safari knuckles can be changed from left to right. moving the tie rod mounts to the front for hydraulic/ orbital steering.
well it's what we did.
- mudlva
silveradoman wrote:The nissan safari knuckles can be changed from left to right. moving the tie rod mounts to the front for hydraulic/ orbital steering.
How did this affect your steering?
Re camber etc
- Bush Crasher
Camber is un changed because your mounting back in the same position just on opposite sides.
We did cut off the drag link arm for reasons i can't remember but if you need to cut small amounts at a time because its hollow.
O and gusset knuckles while your there if not all ready done .
- mudlva
And last question if i may.
Panhard arm? Did it fowl the ram? Or did you go to a 4 link at the same time?
Opps that 3 but you know how it goes....
if you have a look at the howat D class buggies you'll see another way to go about a saf hydro setup
- Bush Crasher
hey, yea running 3 link with custom panhard. So not sure.
All ways how it goes mod one thing and 5-6 mods around it, now it works nicely.
- Checkerhead
Where did you get to on this Mudlva?
- mudlva
Been told by two 4bys that ran the h.d. box to just adjust the steering link arm to suit and drive it. Both had twisted shafts and neither broke theirs. One is still going now on second owner and it had the shit kicked out of it for over 5 hard years. It had the twist after the second ran. It was running a 350 and the foot was always 2 inches below the floor boards and screaming.
Cant afford hyrdo so just going to carry a std spare box and keep on wheeling.
Bought a new adjustable link off warren and found its to long
So looking at shortening another std link them bracing it up or trying to pull the pitman arm off and turn by 1 tooth. Issue of course is its bent so it may not come off.
Bit stuck at the moment....
Still keen on hyrdo just need a couple of $k to get it under way.
It will help solve a couple of other problems at the same time
- mudlva
Ok it looks like im pulling the pitman off...
Any susgestions tips or advice?
Hopeing to leave the box inplace if i can
Hydraulic puller, some quick heat and a hammer to shock it.
If not going to hydro steer, possibly fit hydro assist, how much travel does your tie rod and drag link have.
Tim
Tim
Have a look at
http://www.lowrangeoffroad.com/hydro-assist-ram-kit-by-trail-gear.html
and, note this is for a toyota box
http://board.marlincrawler.com/index.php?topic=10579.0
note that I have got a couple of kits
Tim
Tim
I had a bastard of a time trying to get the pitman arm off an old steering box.
What did it in the end was to heat up the pitman arm around the steering box shaft, sprayed some CRC Penetr8 freeze off spray onto the steering box shaft while having a gear puller as tight as I could get it and then gave the arm one solid smack with a hammer to shock everything. Gave a little pop and came free!
The difference in temp of the two parts as well as the penetrating properties of the spray seemed to do the trick nicely
Toyhatsu Bitsalux
- mudlva
Cheers mehrts
- mudlva
Ok further developements.
Found that the pitman arm fits onto a spline that will not allow it to rotate by one click.
So machined my new adjustable link arm down and will get in re.welded up tomorrow.
Its c.m. tube so out of my welding league.
Users browsing this forum: No registered users and 12 guests
