What are these worth??
Mk patrol axles..any interest in these? If so how much are they worth? Cheers. Josh
Re: What are these worth??
Where are you located? Any idea on ratio? I want the front axle.
slidenyo picked up a MK front axle from Weemsy a couple of years ago for $150
Ill need to double check on the ratio. Im pretty sure itll be 4.625 or 4.875. Plan is to put in terrano but nappies are expensive! Do you still have your terrano? Are you going to do a SAS? Ill hoist them off the rack when i can to check for you. Cheers.
And im in Auckland.
there's nothing wrong with that early patrol stuff but it doesn't hold a very high value
[youtube][/youtube]
Cheers mate if you could check the ratio that would be great.
Nah definitely not straight axle swap for the WD21, long travel a-arms offer so much more.
This would be for another vehicle (hint hint it's British), nice and simple, just hang it under the front with some old fashioned lief springs with a couple of wedges to set caster.
Could probably take both, keen, will PM you
mudslug88 wrote:Ill need to double check on the ratio. Im pretty sure itll be 4.625 or 4.875. Plan is to put in terrano but nappies are expensive! Do you still have your terrano? Are you going to do a SAS? Ill hoist them off the rack when i can to check for you. Cheers.
Pmed you
Got a spare front diff if you need it josh.
Users browsing this forum: No registered users and 19 guests
