radio in the truck failed cutting in an out with power , pulled it installed newer unit , no fn sound , same as old unit but constant power ,
A tad confused by this
Radio
Radio
Re: Radio
Got same issue never before in last 6 yrs suddenly clock which never worked starts on and off I suspect a dodgy earth up behind peddles where my 24 to12 inverter is or behind radio / a real bitch to get to may even be memory feed mine is a sony radio
Re: Radio
My radio doesn't always start with the truck seems to be linked to the temp gauge oil gauge and speedo they also like a sleep in All comes on eventually except the fuel gauge which seems to have random reading issues like says its on empty when its full and 3/4 when its empty oh and the rev counter reading 2k rpm at idle. Normal safari character traits.
Re: Radio
My first thought would be rubbish OEM speaker wiring, possibly shorted - it's not that hard to drag new stuff, and I would recommend re-wiring everything (power and earch as well)
Second would be the configuration on the head unit - it may switch between Amp-out (line level) and speaker-out.
And if you throw "safari" into that, then the 12v reducer would need looking at.
Re: Radio
oh the tach died a few weeks ago , plus a few other accessories that was a faulty pug on a small inverter wiri auto fitted, that's repaired but still no radio sound , will individually wire some speakers to radio see if it lives , do it to both old an new ,luck be with me
Re: Radio
Mine did the same thing when upgrading the radio to a newer unit.
Issue was the limited power supply from the 24-12v converter.
Put in another 24-12v converter just for the radio and that solved the issue.
I did also have a look round for 24v sterios and they are available through truck parts stores.
92 LWB Safari TD42
Re: Radio
old radio on battery charger works ,discussed with auto sparkie who fix other problems going to check it out for free
Re: Radio
it was a earthing problem all fixed bloody thing
Users browsing this forum: No registered users and 24 guests
