GU factory diff locker in GQ
4x4rookie
Postby 4x4rookie » Sun May 13, 2018 9:25 am
Hi
I've recently taken 2 GU axles and put them under a GQ
The rear GU has a factory locker, I have the solenoid set up from the GU donor vehicle.
Can I use the GQ vacuum line powered from the vacuum pump at the back of the alternator to run the locker ?
I would just put a T in the pipe going to the brake boost
I realise the GU was 12 volt and the GQ 24 volt so will run a step down to power the solenoids from the donor vehicle, just want to make sure I can use the existing vacuum to run the locker
BlakeNZ
Re: GU factory diff locker in GQ
Postby BlakeNZ » Sun May 13, 2018 7:48 pm
is the factory locker engaged by vacuum, rather than pressure from a compressor?(eg ARB lockers)
4x4rookie
Postby 4x4rookie » Mon May 14, 2018 7:30 pm
hi
99% sure vacuum - was in a 98 2.8 diesel lwb patrol
Postby coxsy » Sat May 26, 2018 8:51 pm
jap sourced gqs have a vacuum cans just get two and
attach to vacuum for the boasters line and get ya fed of them
Users browsing this forum: No registered users and 9 guests
