running wires through firewall safari
dangerous
Postby dangerous » Wed Aug 29, 2018 6:37 am
ok so what and were is the best spot to run wires through the fire wall on a safari...
in this case its for a boost and etg usualy I run them round the door but thats a tad untidy, and theres already a bunch doing that.
lokrite
Re: running wires through firewall safari
Postby lokrite » Thu Aug 30, 2018 8:19 pm
drill a rust hole out with a step drill and use a rubber grommet to protect wires . Solves warrant issues as well :D
MihiT
Postby MihiT » Fri Aug 31, 2018 9:39 pm
The above is good advice, except they tend to rust on seams, not so easy to drill!
There is a drain/bung/breather behind carpet on passenger side footwell (also exhaust manifold side) which you can poke wires through if you're precious about drilling. I can't remember if you have to remove the heater core to reach it on the inside or not.
Ant
Postby Ant » Mon Sep 03, 2018 6:58 am
I have used the big rubber grommet on the passenger side (by exhaust manifold)
I just poked a hole in it with a hot screw driver below the cables that are already in there.
92 LWB Safari TD42
dangerous
Postby dangerous » Wed Sep 05, 2018 8:31 pm
sorted... followed a heater pipe through the wall, spotted it as the rubber had perished and I seen day light LOL... its near the stearing rack
Return to “Nissan”
