Overheating Hubs?
Overheating Hubs?
I was wondering if any of you out there have had the issue of overheating hubs?
I have a 1997 Isuzu Mu and my front hubs are hot to touch after a decent drive around town say about an hour's drive.
I have been going out of my mind at what it could be, if any of you lot out there can shed some light on this would be much appreciated.
Ruben
Ruben
- mudlva
Re: Overheating Hubs?
1 driving habits of long slow braking
2 brake pads rubbing slightly siezed calipers
3 wheel bearings to tight
4 or wheel bearings rusty and becoming seized
jack each wheel spin them and wobble them see what appears as friction etc
thats a start
thats a start
- mud_slinger
are the hubs free wheeling or are the always locked, as have seen a few isuzu's with a factory option hub that is full time locked.
needs more curry
0272593533
0272593533
Thanks for your help you guys, I have already ruled out the possibility of what
When I corner it heats up the most.
I have checked these and found they are not siezed.
I still have to investigate this, as one machine screw was giving me grief.
I have had the wheel bearing replaced so there is no way they are rusty and have seized.
I have had auto hubs but replaced them with manual hubs, so they are not locked.
I have tried different types of manual hubs (Anisin and AVM) for some reason since I put the Anisin hubs on this is when the issues started to happen and I cannot think why, I will swap back to the AVH hubs and see what happens.
- Moriarty
Drurban wrote:Thanks for your help you guys, I have already ruled out the possibility of what
If heating up when cornering, points to badly adjusted wheel brgs. Allowing the wheel to cant on cornering forces, and the disks lean on the pads.
- mudlva
Moriarty you have a good point there I have never had thought of that.
This is something that I will need to look into more.
Thanks Moriarty for your suggestion.
Ruben
Ruben
I have manual hubs and after a long drive they do get hot.....
You can hold your hand on them....
And heat sink when stopped.
I notice this when I have to click in the hubs.
So if everything is o.k then its normal.
Don't forget there is a huge amount of energy lost to friction and heat when braking.
Calvin
Calvin
- Moriarty
You DID say that you had new brgs installed? after a shortish run, the will bed correctly, out to their limits, thus inducing a certain slackness in clearance, time to readjust, and your problem SHOULD disappear.
I have exactly the same situation with wheel brgs, the damned thigs are a consumable item when 4wdriving, especially with IFS trucks like mine. Water gets in and that is DOOM for wheel Brgs!!!! I now carry two sets all the time in my garage.
Thanks for your advise Moriarty, I think I will do that with having a set of bearings.
I was just wondering what is past the adjustment collar in the picture below, me being non mechanically
minded.
minded.
Jez Ruben,
They are a mess. Is that the side with the broken CV?
You may have to go back to the drawing board
You have come to the right place for advise from all these great guys.
Simon.
Simon.
sibainmud wrote:Jez Ruben,
Simon.
Hey Simon,
Yes broken C.V tip see photo's on club album on F.B, the mess is all the greese which I left in there.
The Impact driver worked a treat to remove shagged screws, need to find some more to replace old ones, any idea where to get some?
Cheers.
Any OEM bolt shop should be able to help. You just need a sample with you.
sibainmud wrote:Any OEM bolt shop should be able to help. You just need a sample with you.
Cheers for that, Iam guessing the bearing is behind the adjusting collar?
- Moriarty
Drurban wrote:sibainmud wrote:Any OEM bolt shop should be able to help. You just need a sample with you.
Cheers for that, I am guessing the bearing is behind the adjusting collar?
Your guess is spot-on!!
there were three countersunk screws going through that outer lock-ring.
Under the lock-ring, is the bearing keeper. No shims or anything complicated.
If you need a new wheel brg kit at any time, the part number from Superbleep is IF002
before going too far, with the wheel OFF the ground, and grasping the top and bottom of the wheel, can you rock it up and down?
Or use a crowbar under the tyre.
If there IS play, remove the lock-ring, the brg keeper has five holes in it, two are around 7mm dia and the remaining three are threaded for the screws.
using the UNTHREADED holes, and a suitable bar tighten the lock-ring until all discernible play has been removed. (as described above)
replace lock-ring and see which threaded holes line up with any of the holes in that lock-ring. If NONE, tighten the keeper sufficiently to allow the screws to make the holes.
Insert screws and reassemble hubs etc.
Moriarty wrote:Drurban wrote:sibainmud wrote:Any OEM bolt shop should be able to help. You just need a sample with you.
Thanks Moriarty, you have been a big help and also to the others who have commented, it is always good to hear what others opinion's are.
Cheers Ruben
Users browsing this forum: No registered users and 4 guests
