Has anyone had problems with the seat back slipping ???
Set it in place and drive along the road, Hit a bump and it moves
So I took one of the knobs off to see what was happening inside
In 3 of the 4 what ever was superposed to be in there fell out as a course red dust
the 4th one had been jammed up with what looked like the remains of some sort of bottle top.
Any help is appreciated
Ta.
Daryle
Recaro Seats slipping
- rangimotors
- rangimotors
Hi Rangimotors, Thanks for the offer
If I lived closer I'd be happy to take hem off your hands, but I think the cost of freight would be way too much.
If you can't give them away to anyone else and decide that they are going to the dump would you consider taking the knobs and friction pads off and posting them to Hastings.
I have taken mine apart and based on an idea from Geeves on ClubIsuzu, cut some leather washers
http://clubisuzu.proboards29.com/index.cgi?board=Justabout&action=display&thread=1183489405
This has worked well on one seat but not the other ...
I think that it needs a packer behind the leather, will try a washer tomorrow
I had to give up 'cause it's pouring down out there ...
Here is a photo ...
The top is what was in there
Just an update ...
The leather worked ok for a while then I think that it bedded in too much and so started slipping again ... I tried adding a washer behind the leather and it did not help I then looked at adding another layer of leather and when talking to my brother in law who does shoe repairs in his spare time he suggested some sole rubber.
Now this stuff has a fine pattern on one side and is quite firm.
We tried a couple of different thickness and found that 8mm works very well.
I will post up a pic when I find the camera (must have left it at work)
I can make these for the cost of the rubber (which is not cheep) and postage = $10 for a set of 4
Re: Recaro Seats slipping
Both mine were shockers two, go over a bump and they would wind down like the seat was possessed. A real easy option is to unscrew the knob and remove. Obtain a clear bit of plastic tube from payless Plastics roughly 15mm inside diameter. About 50 cents per meter. Cut about 9mm or so mm off. Put it over the spline and put the knob back over the top. Tighten. Throw away those felt washers as they most prob be stuffed anyway. Works a treat. Might have to experement will a mm of longer it the correct tention isn't required. Keeps the WOF inspector at bay.
i cut a couple of shock absorber caps from an old car down works a treat costs nothing only had to do one side of each now i can hardly move them
Users browsing this forum: No registered users and 27 guests
