Project Lemon Extreme Front Axle
I am writing this becouse I've been asked by so many people for details on this conversion and the different ways of doing it
First off why
the solid axle hub is on the left the difference is 33mm extra each side (considering the currant certification limit for spacers is 27mm this is worth while
Issues with the Hub swop... there are none with the hubs both swop without any issues bearing are the same everything bolts over no problems all you need is a spacer ring cut from the brake sheild (or if your going to use the brake spacer ring then you leave the sheild.... the only issue with this mod is with the brakes, there is a slight difference in caliper mounting distances between the solid axle swivel housings and IFS what this means is if you run a IFS disc and caliper bolted onto the solid axle swivil the caliper will be mounted sligtly further out... just enough to make it illegal for certification as not all of the pad is in contact with the disk
Before I get into how too, heres why I did it my way
Moves caliper back inside the protection of the rim
Your not adding extra weight of a spacer
Bugger all people do it this way so its a bit differnt and I like that
Right here goes
We'll start with the difficult part just flipping the caliper over the other side of the posts won't quit line you up ... its actually 1.5mm out, now you can get around this by just using second hand pads or you can mill 1.5mm off the caliper posts or the swivel housing posts .... the better one to do and the harder to mount in a mill
You can also see where I tapped a thread in there to bolt them up, you don't need to as there is space when mounted to fit a nut
That gets the caliper mounted next the hub now to fit the hub, to do this you'll need to grind out the mounting ring on the old brake gard (its no good as a gard now as the disk is way inside of it
With the ring in place you can mount things normally
Before you mount the hub use it to sort your mounting holes in the disk, if your not confident in drilling the holes in the right place heres a trick start out by slotting the two 8mm mounting bolt holes you can do this with a round file if you don't have a mill
With it bolted on flip it over and mark your centers a good trick here is to find or lathe a center punch down so it fits nicely into the brake mounting holes in the hub
Once you've got them marked drill them out progessivly
Heres the finished disk sporting the latest fashion in "multi-fit"
now all you need to do is mount everything
Heres a shot showing the brake tucked away in the wheel
Now for the "spacer" way
This way you leave the caliper in its normal mounting and machine a mount that bolts first to the IFS hub with recesses to fit the bolt heads and then a set of mounting holes that are taped to take the solid axle disk, this bolts the disk in line with the caliper, there are a number of aftermarket outfits making these spacers and this is where the spacer has its biggest bonus it is bolt on you don't need any engineering to do it
Here is a pic of a spacer made to move the standard IFS rotor out, please note this is not certifiable in NZ see the large gap between the outside of the disk and the inside of the caliper
becouse the solid axle caliper mounts are further out not all of the pad contacts the disk and is why you can't certify
To do it to a certifiable level you need to make the spacer alot thicker and run a cruiser vented rotor and the IFS calipers or the original solid axle disks and caliper
The downside of this method is it leaves the disk flush with the inside of the wheel and the caliper sticking further out but it allows you to retain the original brake sheild
Any questions comments please post them on this build thread
Cheers Reece
Oh and when I do get around to making a bolt on ring I'll edit this to show how
