As the title suggests I am wondering if the PTO set up on an SD33 (4x4, Manual) will fit in with a TD42 (4x4, Manual).
I believe the TD is FS5R50A but unsure what box the SDs run?
SD33 box vs TD42 - PTO?
Moderators: Steve_t647, Tech Authors
1989 LWB 5-Seat parts hack. TD42
- passengerpete
Re: SD33 box vs TD42 - PTO?
the pto on gq has six bolts if I remember correctly and only four on mk comply different looking box, ya might get it going but it wont be a bolt on job.
And the gears are different so even if you make an adaptor or redrill for the four studs the gears will not mesh.
No. Got it. Thanks.
