1kz-te Service manual in PDF Format
LandCruiser and Prado Technical Info - 80 series and newer
Useful Auction site to get Factory Specifications
Toyota Free Wheeling hub assy
GEAR RATIO, TIRE SIZE, CRAWL RATIO, ETC. CALCULATORS
http://www.4lo.com/calc/gearratio.htm
TIRE SIZE CHANGE CALCULATOR
http://www.4lo.com/calc/geartire.htm
oooooooooo
Better Calc's : http://www.dfw-tx4wd.org/gears.html
http://www.tlca.org/trails/techexchange/rpmtbls/
Newer diff codes:
A02A / A02B
A = Non LSD
B = LSD
TOYOTA - FAQ's & Tech Articles
Moderators: Steve_t647, Tech Authors
Who knew Prados could fly?
http://www.yankeetoys.org/Docs.htm
Wiring Diagram, 1978 FJ40
FZJ80 Front E-locker Gasket drawing
FZJ80 Locker wiring diagram
Tacoma Locker wiring diagram
4Runner Locking Diff Rebuild
ARB RD08 locker install docs
Front Wheel Hub Rebuild Procedure
AISIN Hub Rebuild Procedure
Toyota EPC #1 Toyota Electronic Parts Catalog, CD #1 (2 required, see below).
Toyota EPC #2 Toyota Electronic Parts Catalog, CD #2 (2 required, see above).
Toyota EPC FAQ Toyota Electronic Parts Catalog info/FAQ.
Air Compressor Install
Product Manuals to help you repair your Toyota!
F Motor
B/2B Motor
3B (11B, 13B, 13B-T) Motor
2H Motor
1980 Chassis & Body
1984 Chassis & Body
1984-1990 Chassis & Body
1986 Maintenance Procedures
Land Cruiser Library
Cruiser Repair
Maintenance data
40series, 60series, 70series, 70PRADOseries, 80series, 90series, 100series
Production chronology and Specifications sheets
Out of print catalogs
Automobile environment relation information
Usage of the winch
8274 - Details, Parts list, Attachment figure
XD9000i - Details, Parts list, Attachment figure
Hi-Lift
All the kind image, Performance table, Parts list
UNI FILTER
Manual
Cruiser Repair
[/url]
Front hub O/H
Front differential assy exchange
Special tool
Toyota pure parts
http://www.yankeetoys.org/projects.htm
Walt's Power Steering Conversion
1976 fj40 with a chevy 327 Using a Scout II pump and a chevy box. The original Scout hoses were used with the exception that one end fitting had to be cut and turned 180 degrees and welded. Modified steering shaft using most of the stock parts.
Charlie Horn's axle conversion
Mike Hartnagel's FJ40 Keg SandBlaster and Tire Carrier
Ian Winston's Body Work Project
Karl Bellve's Electric Locker Install
Kevin's CJ-7 Build-Up Project
Mike Gavin's Rhino Lined FJ40 Tub
Jeff McGarry's Herculined FJ40 Tub
Sean Murphy's FJ40 Restoration Project
Mike Fox's Toyota Truck Project
Daryl's FJ40 Project
Dave Beattie's FJ45 project
Jim Madden's VJ40 York on-board air project
Ken's Shift Lever Seat Replacement
http://www.autoshop101.com/techarticles/technicalarticles.html
Technical Articles
Toyota Series - Electrical
01 Electrical Fundamentals with questions.pdf file size 401KB
02 Electrical Circuits with questions.pdf file size 319KB
03 Electrical Components with questions.pdf file size 517KB
04 Analog vs Digital Meters with questions.pdf file size 35KB
05 Wire, Terminal and Connector Repair w/qu.pdf file size 270KB
06 Automotive Batteries with questions.pdf file size 741MB
07 Toyota Starting Systems with questions.pdf file size 870KB
08 Toyota Charging Systems with questions.pdf file size 850KB
09 Understanding Toyota Wiring Diagram.pdf file size 1.9MB
10 Electrical Diagnostic Tools.pdf file size 784KB
11 Diagnosing Body Electrical Problems.pdf file size 1.31MB
12 Semiconductors with questions.pdf file size 216KB
13 Transistors with questions.pdf file size 42KB
14 Computers / Logic Gates with questions.pdf file size 205KB
15 Overview of Sensors & Actuators w/quest.pdf file size 287KB
16 Electronic Transmission #1 - Operation.pdf file size 574KB
17 Electronic Transmission #2 - Diagnosis w/quest.pdf file size 287KB
18 Shift Interlock System.pdf 241KB
Technical Articles
Toyota Series - Engine Performance OBD
20 EFI#1 EFI System Overview.pdf file size 349KB
21 EFI#2 Air Induction System.pdf file size 500KB
22 EFI#3 Fuel Delivery & Injection Controls.pdf file size 727KB
23 EFI#4 Ignition System.pdf file size 435KB
24 Engine Controls #1 - Input Sensors.pdf file size 793KB
25 Engine Controls #2 - ECU/Outputs.pdf file size 495KB
26 Engine Controls #3 - Idle Speed Control.pdf file size 352KB
27 Engine Controls #4 - Diagnosis.pdf file size 446KB
Technical Articles
Toyota Series - Engine Performance OBD-II
31 Sensors#1 - Mode Sensors and Switches.pdf file size 201KB
32 Sensors#2 - Thermistors with questions.pdf file size 205KB
33 Sensors#3 - Position Sensors with questions.pdf file size 282KB
34 Sensors#4 - Air Flow Sensors with questions.pdf file size 302KB
35 Sensors#5 - Pressure Sensors with questions.pdf file size 261KB
36 Sensors#6 - Speed Sensors with questions.pdf file size 283KB
37 Sensors#6 - Oxygen / Air Fuel Sensors w/ques.pdf file size 328KB
38 Sensors#8 - Knock Sensors with questions.pdf file size 55KB
39 Ignition#1 - Ignition Overview w/questions.pdf file size 239KB
40 Ignition#2 - Electronic Spark Advance w/quest.pdf file size 223KB
41 Ignition#3 - Distributor / Distributorless w/qu.pdf file size 664KB
42 Fuel System#1 - Overview with questions.pdf file size 721KB
43 Fuel System#2 - Injection Duration w/ques.pdf file size 173KB
44 Fuel System#3 - Closed Loop /Fuel Trim w/qu.pdf file size 112KB
46 OBDII#1 - Overview of On-Board Diagnostics.pdf file size 331KB
47 OBDII#2 - Serial Data.pdf file size 289KB
48 OBDII#3 - Data Interpretation.pdf file size 304KB
55 Emission#1 - Chemistry of Combustion.pdf file size 301KB
56 Emission#2 - Emission Analysis.pdf file size 292KB
57 Emission#3 - Engine Sub Systems.pdf file size 180KB
58 Emission#4 - Closed Loop Feedback Systems.pdf file size 233KB
59 Emission#5 - Electronic Spark Advance.pdf file size 130KB
60 Emission#6 - Idle Speed Control Systems.pdf file size 118KB
61 Emission#7 - Exhause Gas Recirculation.pdf file size 227KB
62 Emission#8 - Evaporative Emission Control.pdf file size 148KB
63 Emission#9 - Positive Crankcase Ventilation.pdf file size 126KB
64 Emission#10 - Catalytic Converter.pdf file size 316KB
65 Emission#11 - Secondary Air.pdf file size 107KB
Technical Articles
Web Series - these are the online instruction modules from autoshop101.com
Control Devices.pdf file size 190KB
Circuit Protection.pdf file size 683KB
Understanding Relays with questions.pdf file size 550KB
Battery Basics v1.1.pdf file size 531KB
Battery Service v1.1.pdf file size 478KB
Toytota Landcruiser FAQ, vehicles previous to 1998
http://www.off-road.com/tlc/faq/
Contents
o Disclaimer
o Introduction
* Body Styles
o Series Description
o Availability by(Model Year)
* Frame Specifications
* Engines
o Gas Engines
o Diesel Engines
o Other Engine Suppliers
o Engine Specifications
o ENGINE/CHASSIS COMBINATIONS (PRODUCTION YEAR)
o Performance/Fuel Economy
* Transmissions & Transfer Cases
o Transmission & Transfer Case Ratios (All :1)
* Axles
o AXLE CODES
* Production Codes
* Body Colour Codes
* 40 Series Specific Info
o Production Timeline (US/Canada)
o 55 Series Specific Info
o 80 Series Specific Info
* Maintenance/Modifications
o Breather Relocation
o Glow Plugs
o Ride Harshness
o Steering Wandering
o Transmission and Transfer Removal Tips
o V8 FJ40 Cooling Tips
* Land Cruiser Clubs
o North America
o Australia
* Parts Suppliers
o Legend
o North America
o Australia
Information shamelessly pilfered from:
Das Grosse Toyota LandCruiser Buch
Specter Off Road Catalog
Toyota Trails (TLCA Newsletter)
Toyota Dealer Parts Microfiche
Toyota: A History of the First 50 Years
Toyota Repair manuals
Various 4x4 Magazines Contributors (Although they may not have realized at the time
Rory Arms, Paul Bech, Gary Bjork, Drew Eckhardt, Lars Gottberg, Steve Kopito, Willam Jan Markerink, Park Owens, Marv Spector, Ian Staines, Roy Stockman For the Land Cruiser
Disclaimer
Well, here goes. I've decided to bite the bullet and try to set up the framework of a Land Cruiser FAQ. I do not claim to be a Land Cruiser expert all I am attempting to do is collect the knowledge that the experts on the list have posted over time into one source. I welcome any suggestions, corrections, or additions to this FAQ. I also welcome "articles" about various projects (disc conversions/tranny swaps etc.) Your name will appear alongside your article. The information in this FAQ is to be used AT YOUR OWN RISK. I am not responsible for any death/dismemberment/grief/increase of libido that any errors or misinformation cause you! Also please note: There are NO spelling mistakes in this document. Anything that looks wrong to you is actually just a Canadian spelling . One final note: This document is in essentially public domain. (I can't realy copyright that which I lifted from others) All I ask is that you do not use it for commercial purposes and if you do use it (in a WWW page/newsletter etc.) you do _NOT_ modify it and my e-mail address along with the above contributors names remain attached to it so that anyone who reads it can inform me of corrections or additions that should be made. (And get their name added to the contributors list!)
Introduction
Land Cruisers models are identified by an alphanumeric code. The code consists of the engine series designation letter(s) and the frame desgination number separated by a the letter "J." For example a 2 door with short wheel base and a 2F gasoline engine would be a FJ40. There are also auxilliary codes that follow the main model code and give further information about the vehicle. For instance, the code FJ40LV-KCW is the vehicle mentioned above produced between 01/75 and 07/80 with left hand drive, 4 Speed Transmission, Hardtop, Rear "ambulance" doors, and no roll bar produced for the European market. The extra codes are necessary because of the huge number of variations of each vehicle offered world-wide. There were 2500 versions of the 60 series alone. All the North American & most Australian Codes are described later in the FAQ. The only exception to the naming convention is the 1951 BJ.
Users browsing this forum: No registered users and 11 guests
