v8 barbie make over.....
- tomsoffroad
- Flopsie
Re: v8 barbie make over.....
one of these will help http://www.novak-adapt.com/catalog/shifters/sk2x/sk2xc/
to replace the ugly factory set up
v8 tj...luvs the gas......
also replace these stupid bits of yank wisdom ...
with these....on ipad thingy and can only post one pic at a time ......
lots of little stuff plus fuel line which got mutted in the re wirer.. give it a nudge when pump gets here .....
not bad , shipped on 7th here today
be interesting re pump...
quote
FlowKooler water pumps solve low-speed overheating problems by doubling the water flow rate at low RPM & idle. At 3,500 RPM the flow rate returns to normal to prevent excess water flow at high speed. Independent testing has proven that FlowKooler water pumps produce 20% more gallons per minute at 2000 RPM and 100% more gallons per minute at 900 RPM than any other pump on the market today, including expensive racing pumps. FlowKooler pumps also generate 22% more water pressure inside the engine block than other water pumps. This increased pressure helps suppress engine hot spots, steam pockets, and pinging. In addition to higher output, the FlowKooler water pump is up to 32% more efficient than other pumps, meaning less horse power is required to turn it. The result is overall lower operating temperature by as much as 30 degrees when cruising at low speeds. All pumps are brand new (not rebuilt) and are covered by a 2 Year Limited Warranty.
quote
- Checkerhead
Sounds like a good thing.
all done just the skid plate to do then yeah.....................only thing that don't work is fuel gauge , not bad if you think back to driveshaft pic a few months back....
skid plate done last night bit of weld bit of paint ......................nice
WOF today ..........oh yeah goes forward and backwards yet to test the gears in-betweens....will do today wont be a big fix.....
road legal princess again......right foot down 8 screams as it should gears shift as they should .....
200ks between WOFS
200ks between WOFS
- catalystracing
Has been great looking at this build, the good and the ooppssees, well done.
catalystracing wrote:Has been great looking at this build, the good and the ooppssees, well done.
shits and giggles .........................has had its moments ,last one was a hoot ,but keeps me outta the pub and off the P ....
Must be good to have it on the road again.
Nothing compares to soft-top V8 goodness.
yeah hot as today roof off went for a hoon ....................................
this pic sums it up nicely.....
Looking good. Low mileage vehicle, only driven on weekends.......
TJ wrote:Looking good. Low mileage vehicle, only driven on weekends.......
Owned an d Operated by One Careful Nana
Who knew Prados could fly?
so shes running great now we got power to alternator ...now for the teams event Reefton.......
mean time brought this not long ago ........
was cheap REG & WOF with snorkel hooks and little muds 113ks............drives sweet
plans small lift ,xj front drive shaft, zj like a cv stupid set up, xj transfer case ....bigger tahs got a old warn winch sitting in shed and front bar...... use it for fishing small wheeling trips ......
needs ball joints done so ebay usa.......
$130 kiwi to me door plus 3 tie rod ends .........................................want 45 ish a ball joint shopping around nz.......
love ebay............................
winch back on, waiting for rope to arrive , haven't been wheeling in over a year so looking forward to teams hit out in Reefton.. series 1 landy a disco and me...................................what can go wrong
shits and giggles time again....................if I don't kill it next sunday but....
two days of skids .....nothing to big for our little team but the big boys had a decent hit out...great weekend well thought out by rick and 4x4 events ..cheers chap
the team...........
all 3 drove onto trailers at the end of 2nd day .....................got a thing for old landys now as well......
the team...........
fark knows with pics but yawl gets the idea........................ sorry....
- Checkerhead
Looking good mate.
Need to get my arse in gear and get a truck I can drive as well.
How did your flash water pump go? Notice any difference?
pump worked a treat ....that's some good sticky mud over there hanging on to rad....yeah and I must get ass into gear and get a set of decent sized tahs.......
got a cheap 2nd hand soft top off a 05 off TM.................................soccer mum truck now...............
Put a new lift in the old girl , old one was getting tired ...
Sitting on 4 inches again ...
fitted....shit its been bout a year since its been in 4wd.............................ready for Reefton on the 1st ...kinda..
now they fit.............................
and as per usual on this thing starter has died ...................
wont be much.....................
my cheap $100 and abit go pro thing and the tunnels Reefton ways ....the noise is it hitting screen ...learning...
https://www.youtube.com/watch?v=B6iw1ygGQ3c&t=73s
still plugging away .....
As you said AWSOME! Looks pretty tiiiiiiiight. Good pic and sound for a hundy.
GU patrol 35s ect.
Users browsing this forum: No registered users and 16 guests
