Right... my biggest undertaking so far... (for someone that's not overly mechanically minded)
New Headers
No too dificult... but it took me near 2 full days...
some of the bolts on the underneath are a real B!*ch to get to... and there is no way you can get a torque wrench on them...
also, my arms are scratched to buggery.
The intake and the exhaust manifolds do touch at the rear of the engine... but i got all the bolts in...
I'm pretty sure the intake is sealed, but where they touch it will be putting upwards pressure on the intake, and wanting to create a gap.
is this going to be a problem...?
The other option is to grind a bit off the intake so as to relieve the upwards pressure. (from googleing, others have done this)
All the instruction i could find, said the bolts needed to be torqued to 24 - 26 ft-lb...
this seamed very light to me...
but shes on, and runs smoothly (sat in the garage)...
Smoking heaps as the paints burns off / sets in...
Road test this weekend... but i am ever hopeful all is good...
A Short History of Progress – Harvey’s Wrangler
Re: A Short History of Progress – Harvey’s Wrangler
O[][][][][][][]O
Eat, Sleep, Jeep...
www.nzjeepclub.co.nz
Eat, Sleep, Jeep...
do the grinding. you don't want those two touching each other.
I can see that it looked like a difficult job alright.
Bugger, Bugger, Bugger...
Everything seamed to be going to plan...
She starts fine, and go straight to a comfortable idle.
However, after giving a little bit of throttle, she seams to take longer to return to a steady idle.
i haven't road tested her yet as i want to find out what this issue is...
I have run her up to temp once, with out issue, other than the slow return to idle.
I have looked for a vacuum leak by spraying CRC in possible location, but this did not change the idle speed at all.
I have cleaned the Throttle body
What other ideas are there, before i pull her apart again...
Actually, I might road test her, as googling made mention of her having to relearn the idle due to having the battery disconnected...
https://www.youtube.com/watch?v=It5h9O3btSY
O[][][][][][][]O
Eat, Sleep, Jeep...
Eat, Sleep, Jeep...
Users browsing this forum: No registered users and 31 guests
