Thinking of changing my cj jeep wheel pcd so that I have a greater choice of rims/tyres available to use on the jeep. In my shed the jeep is the only truck I have without six stud wheels. I have spare chev blazer Dana 44 front diff with six stud brakes, so that will be bolt on to the existing Dana 44 front. My question is has any one changed rear drum brakes from 5 to six stud before. Can I get the axle flange and brake drum redialled to six stud? Can an engineering shop do this and what would the likely cost be?
Jase.
changing pcd from 5 x 139.6 to 6 x 139.6?
Re: changing pcd from 5 x 139.6 to 6 x 139.6?
1st question. What axle is in the rear? dyna44 aswell?
Yes, Dana 44 front and rear.
I know nothing about that jeep shit but a general comment for what its worth if your trying to piss about trying to modify rear drum brakes it would be time and effort better spent setting up some disc brakes on the back instead
Wagoneer and chief came 6 stud also on pirate 4x4 they use isuzu axles my need to resrarch that. Xj cherokee disc conversion seems to be the rage over there at the mo
Thanks for the replies. Time for some research on pirate I think.
what about something like this.
http://www.trademe.co.nz/motors/car-par ... 057151.htm
Im sure you can get them/make them to adapt different stud patterns.
Not sure about strength or legality so hoping someone here will comment as I am thinking of the same thing. would be nice to be able to swap the safari tires for the jeep tires and back again with ease.
92 LWB Safari TD42
http://www.trademe.co.nz/motors/car-par ... 677570.htm
Still not the right one but something more like this
92 LWB Safari TD42
I have thought about adaptor spacers. But having planned it out on paper there are sections between the five and six studs holes that would be getting a little thin.
Yes, I thought that might be a problem, anyway keep us posted if you find anything
92 LWB Safari TD42
http://m.ebay.com/itm?itemId=310682574919
Must be possible. Might not want as much as 2" but might work
Any problems running these spacers??
92 LWB Safari TD42
Users browsing this forum: No registered users and 6 guests
