Hi Guys,
Just got some news on the XJ failing a WOF on the below.
Panhard rod ball joint naffed
Exhaust manifold leaking - apparently just the gasket
Needs new front rotors and pads
Steering box mount cracked - does this need certing to be welded up?
94 XJ WOF woes
- Crash bandicoot
Re: 94 XJ WOF woes
Steering box mount crack repairs are classed as a repair not a modification. No cert required.
Panhard rod bushes or ball joint????
Or do you mean draglink ball joint
Re: 94 XJ WOF woes
Its a Jeep so the panhard has a balljoint
Re: 94 XJ WOF woes
Crash bandicoot wrote:Steering box mount crack repairs are classed as a repair not a modification. No cert required.
Ah some good news, would reinforcing it be classed as a modification? I don't want to get it reinforced then find I need to cert for just that. Rather cert later once the rest of the Jeep has been sorted out.
Also looking at the do it once do it right option to mitigate as it is my daily driver.
Panhard rod apparently the ball joint
Any good welders in Auckland on here?
Users browsing this forum: No registered users and 19 guests
