me jeeps 2 clean
me jeeps 2 clean
hi im new to all this, but here goes anyway. just sold the nissan brought the jeep..now what??? just want some info on what i can do to it so can have some fun in the mud...its a 95 cherokee..or any one out this way who wouldnt mind a tag along . cheers wayne
- downunderxj
welcome yeti try not to play in the mak to often as it has lime in it and tends to be a bit harder on your truck try the ashley it great fun down there
PS it might pay to get your self some rated tow hooks and a snorkel
scott gibson
Hey Yeti, just to give you some inspiration. Here is an XJ - some creative work - its a Chevy 383 (bored 350):
http://www.youtube.com/watch?v=GMX7AJzjq-o
http://www.youtube.com/watch?v=woJ2kikXzgI
http://www.youtube.com/watch?v=OylqE22KRo8
- downunderxj
Right on TJ, I know where you have been surfing today, and that would have to be naxja, I saw the same thread. I have already talked to a friend with an SS Commodore with the LS1 motor and told him that when he writes it off one day, make sure the motor is OK
It would make a sweet swap, hearing that sort of sound coming from an XJ deep in Rallywoods
'95 Jeep Cherokee (XJ)
1936 Ford Flathead V8 Colonial Cab (restoration project)
downunderxj wrote:Right on TJ, I know where you have been surfing today, and that would have to be naxja, I saw the same thread. I have already talked to a friend with an SS Commodore with the LS1 motor and told him that when he writes it off one day, make sure the motor is OK
I actually follow http://www.ausjeepoffroad.com on most days.
I want a few SRT8 Grand Cherokees to be wrecked, nice Hemi V8s in them Jeeps.....
- downunderxj
Well, I learn something every day, thanks for the pointer to the ausy forum.
Ian
TJ wrote:wopass wrote:383 chev is not a bored out 350 its a standard bore 350 with a 400sb crank (stroked) or a stroker crank
Oh well, V8 is a V8 - bored or not. I wouldn't mind either way
dont get me wrong here, the 383 is the engine of choice ! ! if i could afford to i would build one !
wopass wrote:dont get me wrong here, the 383 is the engine of choice ! ! if i could afford to i would build one !
Don't worry mate, I am not a huge fan of Chevy's - more want a Mopar Hemi (if I can get my hands one). It will come someday - now if I can get the 426 Elephant in a TJ - now that would be a killer machine.
TJ wrote:wopass wrote:dont get me wrong here, the 383 is the engine of choice ! ! if i could afford to i would build one !
go for the 440 magnum engine,6pac carbs etc...now thats a mopar
Specifications: ( Based On 1970 Information )
Engine Type OHV V-8
Piston Displacement 440 cu. in.
Bore And Stroke 4.32" x 3.75"
Compression Ratio 10.1 to 1
Horsepower @ R.P.M. 390 @ 4700
Torque, lb-ft. @ R.P.M. 490 @ 3200
Fuel Recommendation Premium
The "440 Six Pack" engine was offered in 1969 - 1971. This engine featured three two-barrel Holley carburetors on an Edelbrock aluminum intake manifold, Special Camshaft, Silenced Air Cleaner, low restriction exhaust manifolds and large dual exhaust. This engine was rated at 390 hp and 490 pounds-feet of torque.
jeep s
try this engine out
http://www.dealsonwheels.com/search/det ... x?id=28197
Re: jeep s
coxsy wrote:try this engine out
yeah, right, sure thing..... 86,000$$$ i'll hop on my private jet right now and zip up and get it
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
jeeps
that was the only engine i could find today normaly there are hemi engines for sale there
hey wopass 426 easily eats any 440 ,once above 100-120 ks the 426 will dissapear into the sunset, plus you can take them to 528 cu,but for a mopar man like me im building a 413 max wedge for my hearse, will out torque both of them ,but mine will be inj so slightly economical 10-17mpg but until i get a push button big block auto this is staying there
had quite a bit of work to improve hp and torque hopefully about 180hp with a 2 bbl carter,
vaughan
vaughan
