do they all make this sound
hi all , my jeep makes clunking banging sounds from my suspension when doing u turns going around round abouts ...or any turning really...is this common ???? its a 95 cherokee xj ..comes from both sides front and back depends on what way im turning...cheers yeti....
- downunderxj
Re: do they all make this sound
Mine doesn't make that sound. I presume you are talking about driving on sealed roads/hard surface. Does it make the same sounds doing tight turns on grass - need to see whether it is the drive train binding, or suspension bushes worn.
Ian
Ian
'95 Jeep Cherokee (XJ)
1936 Ford Flathead V8 Colonial Cab (restoration project)
what he said.... Check your bushes, esp the trailing arms.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
sounds like its coming from under my feet when im driving it..does it on road and down on the river..
Its a Jeep thing - we don't understand.
well maybe i do
We have a hiace that makes quite an alarming clunking sound on full lock. First heard it when we test drove it in 1998 - but did find an explanation (can't remember it but it was a non issue) still does it 9 years later - had no issues. Only does it on full lock and particularly when you hit a bump.
well maybe i do
If its a clunking sound, check your control arm and sway bar bushes. Otherwise re-torque all your suspension bolts to proper settings.
Long shot, but check your front axle u-joints (not the driveshaft u-joints). Its long shot because that would only make a sound in the front.
- Driver/Navigator
gidday check your panhard rod mount bolts,they get loose and make a huge noise.look at the bolts and see if there are any little rusty oval marks where the bolts are shifting dude
98 grand cherokee, jacked up, worked motor
thanks for that .... will watch the sports news , then go out and have a look.....
You may also want to check your front UJ's as these can make some interesting noises if they are worn.
