02-03 Feb
02-03 Feb
might kick this one off a bit early. Not quite the weekend but finally got the EFI setup into my truck and working properly. Man what a difference compared to the carby, like driving a whole new truck!
Re: 02-03 Feb
finally got round to replacing the alternator in my bighorn
by god what a f@#king mission and ive only got the old one out so far
time for a few beers and putting the new one in and then all back together again
Re: 02-03 Feb
Will be going to get my exhaust altered and I will be getting my tank lifted so when I go over some low stuff I wont smack the crap out of it.
I will post photos up tomorrow or Sunday.
Re: 02-03 Feb
killed the tridon ute replaced it with this, waiting on nzi insureance to sort them selves out
Re: 02-03 Feb
Well I have been booked by the neighbour to tow a small ride on digger kango thing for him.... With my playdoh.... I only hope it has enough horses to do the job......and its an auto or should I use the 121 hmmmmm
- Suza
Re: 02-03 Feb
keithal wrote:finally got round to replacing the alternator in my bighorn
Yep its a shit of a job especially the oil line for the vacuum pump. If you haven't done so already unbolt the air con pump it will make life easier slightly
- mudlva
Re: 02-03 Feb
kbushnz wrote:Well I have been booked by the neighbour to tow a small ride on digger kango thing for him.... With my playdoh.... I only hope it has enough horses to do the job......and its an auto or should I use the 121 hmmmmm
fella it starts with "T" so it will be ALL GOOD
- mudlva
Re: 02-03 Feb
plus try only weigh 800kg without the bucket.
about he same weigh as the amount on clay that gets lodged under the guards and body work after a good day out
Re: 02-03 Feb
Suza wrote:keithal wrote:finally got round to replacing the alternator in my bighorn
Yep air con pump was the first thing i removed
- ClassicCruiserSpares
- Sausage Shack
Re: 02-03 Feb
Finished painting my rims up, so fitted up my 40s
- mudlva
Re: 02-03 Feb
bejesus those will grip the banks quick fast and flip you onto ya roof if one not careful ah
good stuff......so jealous
- muddyhilux
Re: 02-03 Feb
mudlva wrote:so jealous
x2 that'd be a dream setup for me,might get there if i win lotto
Re: 02-03 Feb
hell now thats a set of tyres i have the same rims do you now what they are off?i know they are off a cruiser but any idea what model 60 ,80?
Re: 02-03 Feb
only replaced radio antenna, had to near take the left hand guard off to do it
- Sausage Shack
Re: 02-03 Feb
datsunsafari wrote:hell now thats a set of tyres i have the same rims do you now what they are off?i know they are off a cruiser but any idea what model 60 ,80?
There 17" rims, that Ive spun and flipped the centres
They come off like a 2010 prado but the very base model one.
Re: 02-03 Feb
keithal wrote:Suza wrote:keithal wrote:finally got round to replacing the alternator in my bighorn
and if you havent got it back together yet, leave the fourth (#### one,closest to turbo) bolt out..makes life sooooo much easier next time. it is not required to hold the ac on
Re: 02-03 Feb
was all back together last night
and yes that bastard bolt was left out
Re: 02-03 Feb
ClassicCruiserSpares wrote:datsunsafari wrote:hell now thats a set of tyres i have the same rims do you now what they are off?i know they are off a cruiser but any idea what model 60 ,80?
thanks for the reply,mine are only 15s so there not the same rims but look identical(mine aren't green though)they are a good strong rim all the same,bloody thick and heavy shouldn't be bending them in a hurry,and i havn't seen any other safari's rolling around on them cheers craig
Re: 02-03 Feb
keithal wrote:and yes that bastard bolt was left out
yes, it really is a bastard that bolt. Just be wary, that cast bracket is prone to breaking without said bastard installed
Re: 02-03 Feb
Went to fit inner tie rod on the TJ after it finally turned up from Morris in the states and made a rookie error of over tightening the castle nut. Ive been hunting everywhere for a replacement tie rod end (inner that meets the pitman arm) in NZ but no store lists the part. Anyone know if the V8 Grand Cherokee upgrade I see in write ups works exactly the same over here or if there is an alternative Chrysler Tie rod I can use.. Help.
- jimny-jeep
- Driver/Navigator
Re: 02-03 Feb
Jeeper wrote:Went to fit inner tie rod on the TJ after it finally turned up from Morris in the states and made a rookie error of over tightening the castle nut. Ive been hunting everywhere for a replacement tie rod end (inner that meets the pitman arm) in NZ but no store lists the part. Anyone know if the V8 Grand Cherokee upgrade I see in write ups works exactly the same over here or if there is an alternative Chrysler Tie rod I can use.. Help.
I've used these guys when they were in Mt Eden in the past and did great work.
Bricon Engineering. Unit 1/7 Marken Place Wairau Valley, North Shore, (09) 444 5571. Hope this helps.
Re: 02-03 Feb
today started with forge1 and his brother coming over to pick up some spare front springs i had(good to meet you guys)then it was off to the pig farm for a bit of a play,caleb(filthy4x4)came along too,was dry up there but still found some mud didn't take that long to drive around with only two trucks,also had francie(the owner)as a passenger.after we had done a lap i atempted to drive a mud bog that hadn't been driven in 20years needless to say i didn't get far tryed to winch through it but snaped my winch rope,caleb tryed a snatch backwards but no good,so francie had to come to the rescue in his 110 landy used his 16500lb super winch with a snatch block off a tree and caleb anchored to the back of him to pull me out backwards so left there covered in mud inside and out,anyone thats been to the pig farm would know that it has some of the stinkyist mud you will ever come across,nothing half an hour and $20 wont fix thanks wash world.no pics from me as usual but caleb might have some.cheers craig
Re: 02-03 Feb
Replaced a torn cv boot and replaced a bent tie rod assembly from going for a play yesterday. Was worth it for the fun.
Re: 02-03 Feb
Yep, as Craig said went to the pigfarm. Ruined my nostrils for the day
Was a bloody good day though, always good to find some mud holes in a drought
027 MUD GEAR - (027 683 4327)
Check our facebook:
Re: 02-03 Feb
Well on Saturday went out to Karaka and had my tank lifted which turned out great job went without any hitches which is always good in my books, I promised some photos but unfortunatly I took them with my Smart Phone and then it decided to shit itself so Iam phone less WHAT DO I DO NOW AAARRRGH Help.
Nah serious what a great way to start the week.
Re: 02-03 Feb
Went on a club trip from Roxburgh, over to Piano Flat via. Gem Lake, stayed the night at Piano Flat then over the Old Man Range to Fruitlands today. Was an awesome trip, some real big washouts, few sketchy moments and having my locker working would have helped but everybody got there with 1 tyre being the only victim.
Re: 02-03 Feb
Nice JUZ that trip is on my to do list. that swb 70 looks like its had a bit of work done?
Re: 02-03 Feb
Lawrence wrote:Nice JUZ that trip is on my to do list. that swb 70 looks like its had a bit of work done?
Definately worth it! but take atleast two trucks.Parts are very very washed out. Swb 70.... the only bit swb 70 is the body.
Re: 02-03 Feb
juz wrote:Lawrence wrote:Nice JUZ that trip is on my to do list. that swb 70 looks like its had a bit of work done?
Don't think I've ever been up there when its been that dry...
Who knew Prados could fly?
Re: 02-03 Feb
wjw wrote:Don't think I've ever been up there when its been that dry...
Glad it was! would be a real mission getting up to Gem Lake in the wet..
