only half of an achievement.
starting fitting a KZJ78 electric locking diff head into a KZJ95 rear diff housing. but need an e locker gasket as a template for where I have to drill new holes and cut some housing away.
so will finish another day.
3rd-4th october 2015
Re: 3rd-4th october 2015
You will need to do some cutting and also weld a new land for one of the holes. I used the new diff and a long drill to drill and then tap a new hole.
kbushnz wrote:You will need to do some cutting and also weld a new land for one of the holes
yeah, i'll use the gasket to mark the right place to cut.
kbushnz wrote:I used the new diff and a long drill to drill and then tap a new hole.
my drill bits aren't long enough, but with the gasket I can get holes in right place.
that's the plan anyway....
Users browsing this forum: No registered users and 2 guests
