19th and 20th, November
Crawlerer79
Postby Crawlerer79 » Sun Nov 20, 2016 8:49 pm
What did everyone get up to?
Dad and I headed down the Selwyn River for a bit of a drive, need to get my Disco out as its been sitting around a while (started up first pop I might add :D :D :D :D )
After messing around for about an hour I managed to find the one log in the whole river, and buried it in my bead (Even with 26psi).
I was driving down the main stream of the river and hit a soft section of pea gravel so I nailed it and collected a log that was submerged (that I couldn't see obviously haha).
After changing to the 7.50x16 spare we called it a day and headed home. Only when we arrived home did we find I'd done the same to the rear (except not as bad)
On with another 7.50 we had lying around (I'd hate to know how it got such horrid camber wear)
Suddenly looked a lot rougher!!!!
First one again
Total damage
Sorry, I know it's pic heavy, that's just me :roll: :roll: :roll: :roll:
Anyways, cleaned one out, nearly dropped the wood inside the tyre haha that would've sucked!!!! Anyways, that's my weekend....
'Lando' - 1994 V8 Disco
Flannel
Re: 19th and 20th, November
Postby Flannel » Mon Nov 21, 2016 10:06 am
Fitted & tested the $150 awning i got from Supercheap online deal. 2.5 x 3m. Very happy.
Crawlerer79
Postby Crawlerer79 » Mon Nov 21, 2016 11:13 am
Flannel wrote:Fitted & tested the $150 awning i got from Supercheap online deal. 2.5 x 3m. Very happy.
Looks good.... does it just come with the two poles or has it got another two so you can park your vehicle under it? Cause that could be good for trips away rather than having to take down the awning each time
Flannel
Postby Flannel » Mon Nov 21, 2016 2:14 pm
Crawlerer79 wrote:Looks good.... does it just come with the two poles or has it got another two so you can park your vehicle under it? Cause that could be good for trips away rather than having to take down the awning each time
Nah its a pull-out awning, attached to the truck. 4 poles would be more of a gazebo...
edit: its back on sale too. i paid nothing for delivery either
http://www.supercheapauto.co.nz/Product ... om=5041377
Crawlerer79
Postby Crawlerer79 » Mon Nov 21, 2016 3:27 pm
Flannel wrote:Nah its a pull-out awning, attached to the truck. 4 poles would be more of a gazebo...
Oops didn't look close enough at the photos.... definitely looks good tho
Postby coxsy » Mon Nov 21, 2016 6:18 pm
took xtrail of Rotovagas friday nite que to leave Auckland wasn't to bad ,
saturday drove to Taumaranui to check out a 4wd place called Gobush, got taken around the place in cut down vitara with interesting tyres ,trip details confirmed ,drove back to Roto ,
Users browsing this forum: No registered users and 1 guest
