Yesterday i decided to remove my side panels of my lux and inspect a crack that I had noticed in the engine bay. Much to my sorrow i found 3 good rust points two of them my screw driver went straight through into the cab
My question is does anyone know someone or a place where i can get these rust holes ground out and welded along with the cracks in the engine bay and not get ripped off like when i paid $500 to fix a small hole bellow the pillar and they just bogged (which is where it has rusted out now)
A good cancer removal place in Auckland?
Re: A good cancer removal place in Auckland?
Shop around, if you do the prep you might luck in and get someone willing to do it for beers or a few bucks.
Did you want good, or cheap?
Sh0tgun wrote:i paid $500 to fix a small hole bellow the pillar and they just bogged (which is where it has rusted out now)
have you checked for a leak problem if the same areas continuing to rust out?
Doesn't have to look good cause it's hidden behind the wheel arch haha.
The A pillar did have some rust and a leak awhile back, been fixed and its above these patches so i believe that is to blame.
Would anyone be willing to lend a hand for beers or bucks or a combo of the two?
Users browsing this forum: No registered users and 12 guests
