Range Rover Wheel options?
RangieNoobie
Postby RangieNoobie » Fri Nov 14, 2003 12:21 am
Hi all,
This might seem like a dumb question to most of you, but here goes anyway.... :D
Background:
We are looking at buying an early 80's Range Rover with large Mud Terrain tyres on it.
I would not be keen to use these tyres/wheels for everyday on-road use due to excessive tyre wear and poorer on-road handling characteristics.
The idea is buy a second set of tyres/wheels for on-road use keeping the others for playing off-road ...
.... now the Question:
Besides the same vehicle, what other makes/models of vehicles rims will fit on an early 80's Range Rover?
RangieNoobie
lowbox
Postby lowbox » Fri Nov 14, 2003 6:14 am
Rangie wheels are the same as a lot of other landrover products but not much else. Fortunately there are lots of them floating about from people upgrading their rims to suit mud tyres. Try Jules at two offroad http://www.twooffrd.iwarp.com/ he normally has a few sets with tyres on going cheap. Other good places would be any landrover specialist, landrover parts places and landy clubs. If uyou look around you can get some dirt cheap.
Rangerat
Postby Rangerat » Fri Nov 14, 2003 8:05 am
Gidday
I happen to have 5 original Rangie wheels with 3/4 worn AT's that I would let go for around $400ish
I'm in Feilding.
Rat.
suzukisam
Postby suzukisam » Fri Nov 14, 2003 8:41 am
I understand the early rangies are 5.5" PCD with 5 stud, which happens to be the same as Large Fords (F-100's Transit etc), Suzuki, daihatsu, lada and a few other obscure brands Kia sportage etc. You would have to check offsets.
Cheers Lester
lilpigzuk
Tiger Balm
Postby lilpigzuk » Sun Nov 16, 2003 6:34 pm
All Classic Rangies (1970-1994) have the same stud pattern as the Landrover Discovery (Series One) and 90/110 (Defender).
Alloys for these are fairly pricey so shop around.
Rex
74 Rangie
81 Rangie ute
91 Disco
suzukisam
Postby suzukisam » Wed Nov 19, 2003 4:16 pm
look here:
http://www.4x4.net.nz/4xSale/main1.asp
some 15x8's in palmy north
lester
Bodge
Re: Range Rover Wheel options?
Postby Bodge » Thu Nov 20, 2003 9:59 am
RangieNoobie wrote:We are looking at buying an early 80's Range Rover with large Mud Terrain tyres on it.
Just how large is large?
What rims are the large tyres on at the moment?
The three position Lucas switch - Dim, Flicker and Off.http://home.off-road.com/~bodgerover/
solihl
Postby solihl » Thu Nov 20, 2003 12:32 pm
I have reversed Disco rims on mine, not the cheapest way to go but you can set them up with the offset you require to suit your RR & tyre combo. Mine were about $55 a rim to have split & reversed. Have it done by a pro then there are no cetification issues. With the extra 50mm offset the 255x85's don't scrub at all at full lock and the added track helps!
lilpigzuk
Tiger Balm
Postby lilpigzuk » Sat Nov 22, 2003 9:42 am
Project Rangie (Sam Parkers one) has these same wheels on it now. Disco steels - reversed. Hes got the AT tyres on it for the road, and getting another set of me for his Simex's. I think Mike at Swages Engineering in Mt Wellington does the cut and reverse at a reasonable price. Thought about it for my Disco, but have scored 2 sets of wide spoked rims so will see if they work without too much guard chopping :)
Rex
