Help with my secondary temp gauge
- Stropper
Ive got a 1kz surf and would like to install a secondary water temp gauge aswell as the standard one, where can i put the sensor probe? T into radiator hoses?
Re: Help with my secondary temp gauge
Measure your hose and order a t adaptor off trade me. Put it in the top hose
as mattman says, this really is the quickest and easiest solution. i tend to have the sensor in the lower half of the upper radiator pipe , so that if i were to lose a little coolant, the sensor would still be reading water temp.(if you get my drift).
something like this comes in several different diameters, so measure before you hit buy now.
http://www.trademe.co.nz/motors/car-par ... 186671.htm
I have mounted mine exactly as Blake suggested. Good advice.
- Stropper
Cheers guys will have a look, some people say put them in the manifold. Much difference?
Manifold? If you have a spare blank in the thermostat housing then use that but if not then the best bet is to put it in the top hose using an adaptor.
Users browsing this forum: No registered users and 11 guests
