Newby. Terrano v6 owner
Posted: Sun Jun 19, 2016 6:12 pm
by Seppe93
Hey guys I bought myself a terrano maybe 6 months ago. Its stock as it comes. Have a few questions to ask. Firstly giving it a lift. I see you can buy lift kits for it for like 100 bucks but then you can get full suspension lifts etc? What's the difference? Are those cheaper lift kits just sort of a show pony sort of deal? Also I've got the v6 petrol engine what's the pros and cons between the two? And finally thinking about getting some mud tyres for it. I want to be able to get the biggest baddest looking ones I can't without doing to much to the truck. But I also want to make sure it's legit road wise because my missus drives it to work sometime
and should she have a crash I don't want it to effect my insurance. Bit long winded sorry.
TIA
Re: Newby. Terrano v6 owner
Posted: Sun Jun 19, 2016 10:04 pm
by fh2014
Welcome.
Firstly what year terrano?
Secondly do some reading up/googling on body lifts and suspension lifts
Thirdly 31x10.5r15s are the largest tyres that fit to an unmodified (assuming early square shape-WD21) terrano and 32x11.5r15s or 33x10.5r15s are the largest that will fit a lifted terrano.
Fourthly don't be afraid to use the forum search or Google the site directory as a lot of information you seek has already been covered here and questions like this can fall on deaf ears.
Good luck
Posted: Mon Jun 20, 2016 6:02 pm
by lax2wlg
The V6 models have much stronger manual gearbox and front diff (R200) and double-offset CV joints (28 spline outer)
33x10.5s will fit standard unlifted (just) on the factory Lego wheels (15x7 alloy)
Posted: Tue Jun 21, 2016 5:54 pm
by Seppe93
Hey sweet guys thanks for the help. My next problem is I think my auto locking hubs are gone. I've got a pair off a mate they are 28 spline. After doing some research online there's seems to be abit of confusion about them changing the year of 1993 from 27 to 28. Just want to make sure I've got the right ones before jacking it up and pulling the tire off.
TIA
Posted: Tue Jun 21, 2016 6:26 pm
by fh2014
easy to check if theyre gone, jump under truck in 2wd and hand spin the front driveshaft with two hands (either way, try both). if the hubs work you'll hear two clicks as they engage and you wont be able to spin the driveshaft by hand anymore. if they dont work or are weak youll be able to keep spinning the shaft.
cant help you with spline count. its not hard to take hub off and count tho
Posted: Tue Jun 21, 2016 6:27 pm
by lax2wlg
Seppe93 wrote:Hey sweet guys thanks for the help. My next problem is I think my auto locking hubs are gone. I've got a pair off a mate they are 28 spline. After doing some research online there's seems to be abit of confusion about them changing the year of 1993 from 27 to 28. Just want to make sure I've got the right ones before jacking it up and pulling the tire off.
TIA
All the V6 models (1986.5-1995) were 28 spline outer (29 spline inner) so you should be good to go.
Only the diesel models had the 1993 changeover that you're talking about, before 1993 the diesel models had weaker tripod type CV joints with 27 spline stub axle.
You don't need to jack it up to replace the hubs.
Posted: Tue Jun 21, 2016 7:46 pm
by Seppe93
Oh mean this is good news! I can't wait to do this when j get some spare time! Getting a lift kit and some 32s this weekend can't wait to share it up!
Posted: Tue Jun 21, 2016 9:51 pm
by fh2014
lax2wlg wrote:Seppe93 wrote:Hey sweet guys thanks for the help. My next problem is I think my auto locking hubs are gone. I've got a pair off a mate they are 28 spline. After doing some research online there's seems to be abit of confusion about them changing the year of 1993 from 27 to 28. Just want to make sure I've got the right ones before jacking it up and pulling the tire off.
TIA
Negative. My diesel 95 has tripoid inners/weaker axles. Mine being one of the last made might have got the leftover bin mind you.
Posted: Tue Jun 21, 2016 9:55 pm
by lax2wlg
fh2014 wrote:lax2wlg wrote:Seppe93 wrote:Hey sweet guys thanks for the help. My next problem is I think my auto locking hubs are gone. I've got a pair off a mate they are 28 spline. After doing some research online there's seems to be abit of confusion about them changing the year of 1993 from 27 to 28. Just want to make sure I've got the right ones before jacking it up and pulling the tire off.
TIA
I stand corrected.
Shit that's interesting.
Nissan can be unpredictable like that!
