Nissan Safari speedo
Help please. I have a 95 Safari auto & would like to know how & where to disconnect the electronic speedo (to save road TAX on all my off road travel)
Re: Nissan Safari speedo
I have put a swith the 88safari there is a green and blaCk wirer I PUT THE SWITH ON THE BLACK ONE .BUT DO NOT TAKE MY WORD FOR IT .Grant81 wrote:Help please. I have a 95 Safari auto & would like to know how & where to disconnect the electronic speedo (to save road TAX on all my off road travel)
we had this big-brother-is-watching conversation a while back...
My understanding on this issue is that you can't legally just add a switch into the dash for turning off the clock while offroad. Its just plain-and-simple illegal, and if you get caught with one fitted I would imagine you would have some explaining to do.
You need to log your on- and off-road activity in a proper drivers log then present it to the LTSA for a refund... some of you logging guys will be able to clarify that I'm sure since thats mainly (and farmers of course) who the rule is for - not 4WDers who maybe do 5k's offroad each weekend.
The effort required to claim back such small amounts is just not worth it in my view, and the actual cost is negligible anyway if you work it out.
Steve.
Steve.
Went down this road 20years ago, Used an Eton axle speedo converter box,the one that alters the speedo depending on whether your in Hi or Low diff range. Removed the low range plantetry gears, did a couple of other mods, quite a bit of time spent on it. Now that ive got a good 4x4 I cant muck around with the Kms (oil changes) So its hanging on the wall.Fitted an hour meter, which cost more than the saveing on RUCs.
Re the posts re speedo and cutting the red wire and putting in a switch
I've a 2006 Ssangyong 2.9 KORANDO, diesel with led speedo, lost as to what wire to cut, I live rural and isolated, jealous of of road, so would appreciate any suggestions
The motor and auto gearbox are from Mercedes, 5 Cylinder engine and 4 speed auto.
late model vehicles are a bit tricky. in a lot of cases the ecu uses speed as an input. with no speed input they can go into limp mode.
some don't even have a gearbox speed sensor, but use the abs sensor rings as speed inputs.
Users browsing this forum: No registered users and 24 guests
