hi i have a chinese mig welder it will not spool wire out freely i have taken the tip off the torch and still no better it just clicks. it will go out then will just start clicking as soon as the wire hits the peice im welding, it welds ok just wont spool wire out.
hope someone can help me.
thanks.
martin
chinese mig spool problem
- Genie4x4
- Driver/Navigator
Re: chinese mig spool problem
you tightened the feed clamp down between the roll and the outfeed? Is the copper tip clear and not blocked?
Pull weld wire out of cable/liner and blow back liner with compressed air, sme time crp build up in liner and jams, although your description sound more like wire feed motor stops
pedro
pedro
yes tightened the clamp up then off again copper tip is all clear and i have also tryed without the tip to rule that out. will try blowing compressed air down the cable liner
if you loosen the feed clamp and pull the trigger does the feed roller turn ?
yes it is just when there is too much tension it just clicks like a ratchet
Have a look at the gears that take the drive from the feed motor to the feed roller, i bet they are nylon and slipping under load
well took the gears apart as dieselboy said it is slipping under load as you can see in the pic one of the gears has not as many teeth as the others, does anyone know why this is? and does anyone know how i can stop the gears from slipping?
I would say get some metal replacements made but I dont know if the nylon acts to insulate the motor etc from the bad leccky stuff in the welding wire. I doubt it would be cheap either.
The teeth look broken off.
Matt.
Matt.
yep they are broken off and they are sitting at the bottom of the gear assembly. i will try contacting the place i got the welder from and see if i can get some spare parts from there.
