25mm ball joint spacer
Heya guys, probly been asked a million times but im interested In putting 25mm ball joint spacers in my 2004 ford courier to get a little more height without having to max my torsions out, what are the cons of spacers? And are they legal? Any info is much appreciated.
Re: 25mm ball joint spacer
I make cnc machined ones for couriers as a kit with high grade bolts etc and have had them certed in various utes ,
The only failures i have seen is when people go to a 2" spacer (i dont do the 2" ones ) the axle moves to far and pops out , its can be fixed via doing a diff drop and relocating the bump stops but in my opinion 1" is the maximum , I also have 12mm ones that you can fit and are barely noticable for wof etc
How much lift would ya get out of a 12mm spacer?
you can match a 2" rear lift by raising or re-indexing the tortions yet retain some downwards suspension travel if you dont run the spacers it will be topped out ,
Trundle wrote:I make cnc machined ones for couriers as a kit with high grade bolts etc and have had them certed in various utes ,
Hey Trundle are you still making these
do u make them for for 91 l200
cornflake wrote:do u make them for for 91 l200
On the mitsi's you should be able to gain around 20mm just by "flipping" the ball joint.
basically unbolting it from the top of the UCA and bolting it underneath, you will gain the thickness of the body of the ball joint and the thickness of the control arm.
Crash bandicoot wrote:cornflake wrote:do u make them for for 91 l200
mad will try that been reading every where but u get all the haters in the establishment with wofs and certs tell me noooooo
Users browsing this forum: No registered users and 4 guests
