Electrics- 24v to 12v
Pj_Marsh
Postby Pj_Marsh » Wed May 04, 2016 5:47 pm
I'm putting a 24v motor into a 12v system. I'd like to keep it 24v for the starter motor and plugs. Did a lot of reading on the net and have found a couple of solutions.
First one is running a third battery for the electrics
Second is replacing all the 24v parts with 12v
Third and preferred by me is chucking in a 24-12 step down before the fuse box. Anyone tried this before? I'm horrible with electrics so this could be a job for an auto electrician but that means paying someone money and that goes against the very fibre of my being. Ideas?
sirLachlan
Re: Electrics- 24v to 12v
Postby sirLachlan » Wed May 04, 2016 6:03 pm
Cant you just run it the same way the stock cruiser is with the 24 volt starter system and 2 batteries .
Put a 12 volt alternator on it . To charge both batteries to 12 volt in parallel .
To start it a relay changes the batteries from parallel to series . And runs the glows n starter motor
Pj_Marsh
Postby Pj_Marsh » Wed May 04, 2016 6:43 pm
Ok that sounds simple and therefore I like it- What parts would I need, aside from the 12v alternator?
keithal
Postby keithal » Wed May 04, 2016 10:43 pm
The series- parallel switch from an 80 series landcruiser
Ant
Postby Ant » Thu May 05, 2016 7:27 am
I dont know the cruiser system very well so correct me if im wrong. When the batteries are put in series (24v) for that time alot of your other electrics will have to be isolated. You wont want 24v going to lighs and radios and computers etc
92 LWB Safari TD42
mudtroll
Postby mudtroll » Thu May 05, 2016 8:10 am
It would be a lot easier, cheaper & better to change the starter motor & glow plugs.
Pj_Marsh
Postby Pj_Marsh » Thu May 05, 2016 10:41 am
I've got a 12v 2H starter that has a hole in the side but im thinking I could swap some of its components out to the 24v 12H-T starter I have, changing it to 12v. Anyone tried that?
sirLachlan
Postby sirLachlan » Thu May 05, 2016 12:02 pm
Ant everything else in the vehicle is still only connected to one battery so only receiving 12 volt .
Personally I would just 12 volt the motor . Surely theres enough oem parts lying around that will work fine . As opposed to trying to re invent a 12 24 setup
Pj_Marsh
Postby Pj_Marsh » Thu May 05, 2016 12:08 pm
Yeah I'm kinda inching that way. Might price up both options and see what comes out on top.
Crash bandicoot
Postby Crash bandicoot » Thu May 05, 2016 7:28 pm
put the windings and stator from a TD27 starter into the TD42 starter body or just change the part that bolts to the gearbox, the solenoid for the spigot/ ring gear engagement is just that, a large electro-magnet it wont care what current it see's.
replace 24 alt with that of a TD27 and then just buy TD27 glow plugs.
or is that too simple
Pj_Marsh
Postby Pj_Marsh » Thu May 05, 2016 7:35 pm
Very simple if it was a nissan
Crash bandicoot
Postby Crash bandicoot » Thu May 05, 2016 10:46 pm
Pj_Marsh wrote:Very simple if it was a nissan
well short of a half tap wiring system and having unblanced charging problems.... have you investigated the parts compatibility between your 12 volt/24 volt combination.
just because I made the assumption it was a td42, doesnt mean it wouldn't work for an Isuzu toyota john deere what ever it might be.
eg if it was a landcrusier what 12 volt glow plugs are compatible, what startermotors share the same winding body where you could change the spigot end over or as above alternators, there all made by bosch or hitatchi or copies of them under contract for car manufacturers anyway. :idea:
Pj_Marsh
Postby Pj_Marsh » Fri May 06, 2016 6:50 am
I've got a few bits from a 2H(12v)- which is basically a non-turbo'd 12h-t, which is the 24v engine. I'm going to try change the components of the starter over from the 2H to the 12h-t, like your td27/td42 idea. Should work, not sure about the plugs though ill have to dig a bit deeper
diogenese
Postby diogenese » Sat May 07, 2016 7:13 am
I'm putting a 2H-T from a 24v 60 series into my 12v 40 mud truck. I have gone for a cable stop control, 10.5v heater plugs with a manual button and I'm going to try to swap the starter motor electrics from my old 12v b engine to the nose cone on the 2h unit. I'll let you know how the motor swap goes later this weekend , wish me luck!
Pj_Marsh
Postby Pj_Marsh » Sat May 07, 2016 8:02 am
If you have trouble with the 3b starter I've got a spare 2H starter that has a wee hole in the side that might be good for parts
Return to “Tool Shed”
Users browsing this forum: No registered users and 9 guests
