Diff Breathers - What to buy and where?
stealth
Postby stealth » Wed Sep 28, 2016 9:22 am
Hi Guys,
Have hori'd up some temporary breathers using some poor quality hose I had lying around for a trip but what to make a more permanent fixture, I have seen a small blue type hose used but have no idea what it is or where to get it from, so what have you used or know works?
Thanks
BlakeNZ
Re: Diff Breathers - What to buy and where?
Postby BlakeNZ » Wed Sep 28, 2016 10:53 am
have a look on trademe at"diff breather kit"
http://www.trademe.co.nz/motors/car-par ... 845166.htm
but even fuel line hose works fine.
likemagic
Postby likemagic » Wed Sep 28, 2016 8:32 pm
you can get an assortment of pneumatic fitting from most engineering supply places and roll you own.
Maurice
KZN185, 1KZTE running needing birthday
wjw
Postby wjw » Fri Oct 21, 2016 6:59 am
I bought some plain old clear tube from para rubber, can see if there are blockages then
Who knew Prados could fly?
Tumor
Postby Tumor » Fri Oct 21, 2016 11:56 am
I was wanting some as well.
Thanks for the tips
Life is better off-road
Crawlerer79
Postby Crawlerer79 » Tue Dec 13, 2016 8:08 pm
Debated starting a new thread, but decided my query was close enough. Should breathers be brought all into one manifold or not? I've seen kits that run all the breathers to a manifold which then runs one line up to the dirty side of the airbox but I've also heard that the change in pressure of one breather can mess with other lines etc. not too sure on the full extent of supposed issues tho. I'd be looking at running breather from both diffs, gearbox and transfer case of my Zook, and maybe some from the engine. Thanks
'Lando' - 1994 V8 Disco
wjw
Postby wjw » Wed Dec 14, 2016 10:31 am
I've always run everything in together.
Crawlerer79
Postby Crawlerer79 » Wed Dec 14, 2016 11:58 am
wjw wrote:I've always run everything in together.
Thanks, good to know. I figured that if so many manufacturers sold them running all together then they must work fine, but then for people to go to the effort to run all separate lines maybe there is some truth to their story. Thanks
Other opinions????
wjw
Postby wjw » Thu Dec 15, 2016 5:25 am
Other opinions????
In the Prado I had an airbed pump and large 1/2" hoses to keep the water out of the engine, diffs etc. In the cruiser I used clear fuel hose
Return to “Tool Shed”
Users browsing this forum: No registered users and 12 guests
