2nd opinion, are my batteries stuffed?
wjw
Postby wjw » Thu Nov 23, 2017 6:32 am
Hi Guys,
I have had to jump start the 80 quite a few times over the last 3 weeks. Over the last 6 months both batteries have dropped to 7 volts (as a pair) 4 times. 3 due to kids leaving interior lights on and once due to a seized starter motor.
When parked up, I get a voltage drop of about .4 Volts every 12 hours. I don't have a multi-meter that I can put inline to measure, so this is the best I have for now.
When the engine is at idle I get between 13.8 and 14.2 Volts depending if I measure directly on the batteries or look at the digital gauge I have in the dash.
The batteries were in the truck when I bought it, so will be at least 8 years old.
Before I bite the bullet and spend $800 odd on new batteries, is there anything else I should check?
Thanks,
Bill
Who knew Prados could fly?
mudtroll
Re: 2nd opinion, are my batteries stuffed?
Postby mudtroll » Thu Nov 23, 2017 7:19 am
No expert but I'd thought 8 years of battery life was very good, new battery time.
Taz
Postby Taz » Thu Nov 23, 2017 7:26 am
Give them a good long charge if you haven't already with a decent charger and then check the voltage under load for a drop. It's not enough to use the vehicle to charge them even if you go for a decent hoon in my own experience.
sirLachlan
Postby sirLachlan » Thu Nov 23, 2017 7:29 am
Yea you've done well having them last that long .
You'll prolly get the better part off 100 dollars at the scrappy for your current ones aswell
wjw
Postby wjw » Thu Nov 23, 2017 9:12 am
Taz wrote:Give them a good long charge if you haven't already with a decent charger and then check the voltage under load for a drop. It's not enough to use the vehicle to charge them even if you go for a decent hoon in my own experience.
I have a proper 10 amp conditioning charger, fully conditioned both (disconnected from the truck) after the last dead flat, took over 12 hours for each battery.
Looks like I need to go shopping.
SMOKEY
Postby SMOKEY » Thu Nov 23, 2017 10:10 am
Bill ---- aren't you a POM or do you have Scottish ancestry ??????, Get those short arms into the bottom of your long pockets and buy NEW ONES, with standard lead acid batteries any thing over three years is a bonus now days. Mine are six years and I would say next winter I will be due ------ for Dollars :( :( .. ----- I'm still looking for the Crank Handle hole.
FITZY.
wjw
Postby wjw » Thu Nov 23, 2017 11:10 am
SMOKEY wrote:Bill ---- aren't you a POM or do you have Scottish ancestry ??????, Get those short arms into the bottom of your long pockets and buy NEW ONES, with standard lead acid batteries any thing over three years is a bonus now days. Mine are six years and I would say next winter I will be due ------ for Dollars :( :( .. ----- I'm still looking for the Crank Handle hole.
FITZY.
Yea I think I need a crank handle.....
wjw
Postby wjw » Thu Nov 23, 2017 11:19 am
anyone got any suggestions other than
https://www.centurybatteries.co.nz/reso ... /200008415
Which are the same as my existing ones.
wjw
Postby wjw » Thu Nov 23, 2017 1:55 pm
Didn’t notice this before, but one of the batteries has a cracked casing
Have bought these
810 CCA, biggest I could find without spending a fortune.
Taz
Postby Taz » Thu Nov 23, 2017 9:24 pm
Stink one.
Return to “Tool Shed”
Users browsing this forum: No registered users and 22 guests
