2lt tacho pulse
imsohi
2lt tacho pulse
Postby imsohi » Sat Mar 30, 2013 11:12 am
hi all
i cant get my tacho reading in my lj71 prado, i have changed from a 2lte pump to a 2lt one, is there any differences in the siginals they produce and what sort of readings should i get off the pump for tacho? cheers
tweake
Re: 2lt tacho pulse
Postby tweake » Sat Mar 30, 2013 1:18 pm
totally different.
afaik the tacho feed comes from ECU not directly from the pump.
you will need to change the tach itself or fit a converter.
imsohi
Re: 2lt tacho pulse
Postby imsohi » Thu Apr 04, 2013 5:35 am
what am i converting it from ie what signal did the ecu give the tach the new pump gives an ac pulse i think would parrot and sons deal in this?? cheers
kbushnz
Re: 2lt tacho pulse
Postby kbushnz » Thu Apr 04, 2013 3:01 pm
I used this Jaycar kit to change the signal from my manual pump to tacho
When I got rid of the electronic fuel pump in my 1KZTE....
Note: manual pump is a hybrid 2LT one so should have the same tacho pickup on it...
http://www.jaycar.co.nz/productView.asp ... TID=965#11
jj1959
Re: 2lt tacho pulse
Postby jj1959 » Mon Jul 09, 2018 10:17 pm
Just seen this post. Having the same problem. Just swapped on a KZJ71 body. The link no longer works to jaycar. What was the part called & would you still have a part #
kbushnz
Re: 2lt tacho pulse
Postby kbushnz » Tue Jul 10, 2018 3:58 pm
Its been discontinued.
https://www.jaycar.co.nz/speedo-correct ... t/p/KC5435
The replacement kit may not work.
As the previous kit could be adjusted to different input signals and then pass them thru as new signals.
Best fix is to get a tacho from a 2LT and swap them over in your instrument cluster.
Did that for mine as the Jaycar kit was a bit jumpy...
Calvin
Users browsing this forum: No registered users and 32 guests
