80 series ignition feed
Hi all.
I am looking for a 12V ignition feed in the engine bay of my 80 series diesel truck.
It is only required for energising a relay but I do not want to go through the firewall if I can avoid it.
Has any one an idea where one is?
PS. I have had a short poke around with a multimeter but had no luck.
Ph 0212078472
Ph 0212078472
- mudlva
Re: 80 series ignition feed
Alternator trigger wire??
what exactly are you trying to do? as I have the fsm but its a stab in the dark to help you..
there is a fuse box in the engine bay that has a ign side to it and a connector.
Tony.
Cheers for the input guys, I have some work to do tomorrow.
Ph 0212078472
Ph 0212078472
make sure there isn't a high drain on that circuit otherwise it could cause starting issues
as Mudde1 said there is a black boxmounted on the drivers side wing about 6" back from the battery box
Who knew Prados could fly?
Big wrote:what exactly are you trying to do? as I have the fsm but its a stab in the dark to help you..
I need the ignition wire to operate a relay or another wire that comes alive only when the engine is running.
This relay then powers a 12V feed to the caravan to keep the fridge running when in transit.
Ph 0212078472
Ph 0212078472
I do not have a fuse box on the drivers side that I can see, but there is one on the passenger side, but no ignition wire in there.
Here is a pic of said box.
Ph 0212078472
Ph 0212078472
Jerry wrote:make sure there isn't a high drain on that circuit otherwise it could cause starting issues
It's activating a relay, hardly high drain.
Ph 0212078472
Ph 0212078472
Hook onto the charge fuse, It is the warning light part of the alternator wiring. It will come live with the engine running.
Or you could get a VSR
wjw wrote:as Mudde1 said there is a black boxmounted on the drivers side wing about 6" back from the battery box
This is right... use this little black box. ill take a pic of it if you need to? take the lid off and it has acc, battery points etc
have taken a pic and spoken to pete, was wondering if its because his is a 24v
24 volt or valve?
hachi_roku wrote:24 volt or valve?
24 valve
ChurchurDan wrote:Hook onto the charge fuse, It is the warning light part of the alternator wiring. It will come live with the engine running.
Yes I may have to look further into the charge fuse.
A VSR is of no use for running the caravan fridge whilst in transit I'm afraid.
Ph 0212078472
Ph 0212078472
kiwipete wrote:ChurchurDan wrote:Hook onto the charge fuse, It is the warning light part of the alternator wiring. It will come live with the engine running.
Could you not use that for the trigger on a relay that could run the fridge ?
Seems I do not have this fuse box between the air cleaner and battery.
The 24Valve models must be different so I will have to look further into the charge fuse idea.
Yes I had a poke around this plug too with my voltage meter but could not find what I was looking for either.
Ph 0212078472
Ph 0212078472
It is all sorted and wired up.
I tapped onto the charge fuse under the fuse box. What a mission it was to get to it.
No pictures yet sorry.
The fridge operates from the truck now as it should.
Ph 0212078472
Ph 0212078472
- mudlva
Alternater system
Well it seems using the charge fuse was not the way to go. Driving to work i noticed the instrument lights for the turbo and the cam belt were glowing evr so slightly. I unpluged the feed wire fron the charge fuse to the relay and these lights went out.
I am now thinking I may have to either put a switch inside the cabin to manually turn this relay or find the ignition wire in there?
Back to the drawing board, humph.
Ph 0212078472
Ph 0212078472
- mudlva
Alternater system
Ciggy lighter in cabin
mudlva wrote:Alternater system
Maybe or i may use an mini electronic relay i have to run the big relay. Well be naff alk current draw and shouldnt upset the charging system.
Ph 0212078472
Ph 0212078472
- mudlva
Use the ciggy to trigger the relay.
Ive used this several times for axualry lights. Ac transformers. Air compressors etc
tgere is an ignition feed in the loom to the stereo
Cheers guys. I will try my electronic relay first and if that fails, then I'll look at the ciggy feed etc.
Ph 0212078472
Ph 0212078472
Manual fuel pump?be ign to shutoff solenoid
,or ign to reverse /inhibitor switch wiring..should be a few others around..or just tap a ign fused feed on ign switch or from fuse box
Users browsing this forum: No registered users and 2 guests
