Looking for a dyno tuner who can tune diesels with mech pump.
Only 1 out of 7 so far in ak can do diesels and he's already booked til Christmas
Any recommendations?
Dyno tuner for diesels in auckland
Re: Dyno tuner for diesels in auckland
is that the crowd on great south road down from motorway intersection
thanks coxy but that guy is moving and cant use dyno (he did Tds way back)
bugger , sorry for goose chase
Hey there, any luck with the dyno tuning in Aucks?
Torque Performance might be an option
why dyno tune?
trundles been getting big numbers apparently 245kw must be decent supporting mods though.
Why not dyno tune? Would be good to know a/f numbers to see if more fueling can be added etc.
Trundel has access to a hub dyno
i'm running a little innovate scg-1 afr/boost controller (controller just sitting idle at moment with ungated turbo)
paid $650 for it and stoked with the little thing,
just waiting on funds to get into a gt3267 (gated t3 twinscroll)so i can use the boost controller to manage not only boost but afr also.
cool units if you want to have a nudge at a home tune.
never done a dyno tune myself always just roadtune with a heavy trailer on to check max egts and driveability.
my thought being if its responsive with a couple ton behind it it'll be better without haha
jase
jase
Just googled it and they look good. Seems to be $400 to $600 far a afr wide band unit. Not that cheep unfortunately.
What pump are you running, 10 11 or 12mm?
12mm recased 1hdt pump. up rated injectors (higher crack pressure)
Sounds like a good setup.
Who did the pump? Someone in Hamilton?
raglan diesel injection.
mates a diesel mechanic an they do a fair bit of tractor pull an performance stuff
My 12mm was done by Diesel Turbo Automotive in Hamilton.
Runs well, just looking to make it breath as easy as possible.
Even thinking 3" exhaust is still to small, 3 1/4" dump into a 3.5" would be better.
im running 3" into twin 2.5" with one resonator . factory pto restricts things a bit
Users browsing this forum: No registered users and 24 guests
