has anyone actually done this or is it a huge pisstake to make people f*** their engines... are there any downsides to this,
what does it achieve and does anyone have a video of them doing it.
I am in slight disbelief that people really do this in real life
2 stroke oil in diesel tank
- Driver/Navigator
Re: 2 stroke oil in diesel tank
Get on the UK pajero and terrano forums. You will be very surprised.
How do you suppose 2 stroke oil would fk an engine ? Think about what 2 stroke oil is and where it ends up .
There's plenty of threads about this .
Try the search before the new topic button next time
- catalystracing
- Driver/Navigator
sirLachlan wrote:How do you suppose 2 stroke oil would fk an engine ? Think about what 2 stroke oil is and where it ends up .
possibly because its a diesel engine not a 2 stroke engine?
Well, 7 years of using 2 stroke in my Safari's, and Landcruisers certainly caused no problems, unless running quieter is considered a problem
- catalystracing
[quote=" possibly because its a diesel engine not a 2 stroke engine?[/quote]
2 stroke or 4 stroke does not determine if diesel or petrol, but on the design of the engine. Worked on 2 stroke turbo diesels and high speed 4 stroke diesels when at sea. The reason for the adding of 2 stroke oil mix is to lubricate injectors since sulfur was removed some years back. From reading threads in this forum it is done for older engines whose injector design needed the sulfur. Personally I use Moreys injector treatment, it lubricates and has a biocide that kills diesel diesel bug and helps separate water.
Hope this helps clarify,
cheers Paul.
cheers Paul.
Yes, it's still used on common rail engines as well for lubrication.
- Driver/Navigator
thanks.. I have had a read through some other threads and it seems to have positive effects.. guess ill give it a go and hope for the best
Is this something ya do every tank full like a motorbike or just occasionally? (Monthly, etc?)
Thanks
Thanks
Only works when it's in there .not along the lines of a cleaner which you would do once every ten tanks etc
If you're putting 200 ml in 50 litres when u fill up a bottle is going to last 5 fill ups which is quite a while
Cool thanks mate.
Users browsing this forum: No registered users and 32 guests
