Hi guys,
Just a couple of questions, i have a Hilux with the 5le motor in it with is injected. Is it possible to turbo these as it is with the 3l or 5l motor?
Do i need to remove the injection and go to the manual fuel pump off the like of a 5l?
What parts will i need to acquire? 2lte pump, turbo manifold and associated pipework? Then i just bolt on?
Any help would be appreciated, would prefer to keep it running the computer but understand it will need to be chipped?
Thanks
Turbo 5LE Motor Questions
Re: Turbo 5LE Motor Questions
you can use 2lte turbo and exhaust manifold, oil and water lines.
intercooler highly recommended.
i would keep boost stock.
chip the ecu to increase fueling.
2.5" exhaust.
2.5" exhaust.
Yeah was thinking of intercooling and bigger exhaust as well. Where abouts do I get the chip from? any recommendations? Thanks
no idea on the chip.
Users browsing this forum: No registered users and 29 guests
