vn v6 in hilux, running rich, aldl setup?
Hey guys, I have just finished putting vn v6 into my hilux, it seems to be running really rich, it use quarter of a tank on 20km drive and seemed underpowered and backfired alot. Does anyone know how i can check fault codes, i dont have engine lights hooked up, tried 12v lamp in aldl plug on engine lamp out put and bridging plug, but no go. I have gone over motor and everything is plugged in and no vacum leaks etc. Also has new map sensor. Could it be temp sensor? Need to get to the bottom of this. Thanks alot
Toyota Hilux LN106
commy v6
3inch efs lift
2inch body lift
front lokka
5.29 trail creeper diffs
longfield chromoly cvs and axles
shimmed LSD rear(basically locked)
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
commy v6
3inch efs lift
2inch body lift
front lokka
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
Re: vn v6 in hilux, running rich, aldl setup?
Checked the injectors arnt stuffed causing it to overfuel thats what id check also no fuel leaks elsewhere n system its what id look at.
- tomsoffroad
- Flopsie
Got an o2 sensor on the exhaust? They come out with the wires for one and a bung hole in the manifold (steel manifold) but no sensor. Go figure lol
I have been told the nz vn never came with o2 sensors? Should i install one or is there a way i can trick ecu? Nah no fuel leaks, first thing i did. How do i test the injectors?
Toyota Hilux LN106
commy v6
3inch efs lift
2inch body lift
front lokka
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
commy v6
3inch efs lift
2inch body lift
front lokka
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
- tomsoffroad
- Flopsie
The narvara my right hand man gets around in is a vn and has an o2 sensor
- tomsoffroad
- Flopsie
Cheers guys, will get one installed and see how i go, i never had that part of exhaust on my headers when i got motor. So i take it o2 sensor does major part and makes big difference to running and fuel?
Toyota Hilux LN106
commy v6
3inch efs lift
2inch body lift
front lokka
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
commy v6
3inch efs lift
2inch body lift
front lokka
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
- tomsoffroad
- Flopsie
Yip my laymans understanding is that it measures how rich its running and adjusts things accordingly. Made a huge difference in the navara. Couldnt pass emissions for cert without it
Hi,
My VN 3.8 car 1989 did not have an O2 sensor, it was the series I VN, think the Series II had an O2 sensor.
Tim
Tim
Ok sweet, well i have series 2 vn, so must need o2 sensor. Will explain why it is running rich then. Will report back on my findings. Cheers
Toyota Hilux LN106
commy v6
3inch efs lift
2inch body lift
front lokka
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
commy v6
3inch efs lift
2inch body lift
front lokka
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
- tomsoffroad
- Flopsie
Im not sure if this one is s1 or s2 Goes hard non the less cheap entertainment
- Crash bandicoot
make sure the fuel reg and return line for the fuel are operating correctly too.
Yeah mine isnt going as hard as i would have expected, quite sluggish, only a little bit more power than the turbo 2.8, which makes me think if the ecu is in limp mode? But i have no way of checking
Toyota Hilux LN106
commy v6
3inch efs lift
2inch body lift
front lokka
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
commy v6
3inch efs lift
2inch body lift
front lokka
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
does it have a black sooty exhaust and blows black smoke?
Nah no black smoke, may be just rich, will get o2 sensor and see how it goes
Toyota Hilux LN106
commy v6
3inch efs lift
2inch body lift
front lokka
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
commy v6
3inch efs lift
2inch body lift
front lokka
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
Users browsing this forum: No registered users and 33 guests
