Vh41 coils and igniters, removal and fit newer coils
Posted: Sun Mar 08, 2015 12:05 pm
by 44jetboat
Hi guys I got a vh41 in my jet boat. Want to remove coils and igniters for newer coils with built in igniters. So if a igniter goes I don't lose 4 cyc just 1. Also coils getting on now motor is 20+ years old . I
My question is will the microtech be ok with this and who would you recommend wiring up in Canterbury
Re: Vh41 coils and igniters, removal and fit newer coils
Posted: Sun Mar 08, 2015 9:46 pm
by Checkerhead
Keen to here the answer to this as I am trying to suss similar stuff for me vh45.
What igniters are you planning to use?
Not sure on Microtech, but from what I can tell my Link G3 will happily run the separate ignitors but I will have to run a wasted spark system as the G3 that I have only has 4 (or 6?) separate ignition channels. Maybe that helps?
Posted: Mon Mar 09, 2015 8:57 am
by Cheesy_Dave
A quick look on the microtech site and it looks like they only have 4 or 6 ignition channels so would have to be wasted spark, I guess it should work, it does with the megasquirt
Edit, looks like it will here is the LS1 ignition wiring diagram, obviously the actual wiring will depend on the exact coils/ignitors and there may also need to be a setting change in the ecu (in the MS2 it is going high or going low), it may pay to check with microtech to make sure this can be changed or if the coil packs you want to use are compatible with how it is configured now
http://www.microtechnz.co.nz/drawings/C ... S1_ign.pdf
Posted: Mon Mar 09, 2015 4:29 pm
by cornflake
plenty people run v8s on both link and microtec
hit up ur local tuner
that drifter chris forsburg runs the same motor in his car like 800hp
Posted: Thu Mar 12, 2015 11:28 am
by 44jetboat
Yeah goes fine onthe micro tech. It is running wasted spark I have since found out. It is running 4 ignition drives. Reason for all this is boat shut down mid corner on me and blew me up the rocks. Boat a bit of a mess now but it is insured. Going through all electrical things now and upgrading were I can.
These are the coils I'm looking at
http://www.ebay.com/itm/390510912900?_t ... EBIDX%3AITThey are rated at 30 kv where the Nissan ones are 21kv.
These have built in igniters so no need for the ptu. Just trying to get measurements off them to make sure they will fit the head ok.
Have found a guy to wire up so will keep updated
Posted: Tue Mar 17, 2015 10:15 pm
by shortylux
Any joy confirming measurements and weather they can be made to fit?
Posted: Wed Mar 18, 2015 6:44 am
by 44jetboat
Hi yep should fit. Maybe just a trim around rubber were coil goes into head. Ordered last Monday so there on the way.
Posted: Wed Mar 18, 2015 7:08 am
by Checkerhead
Awesome!
will wait to hear how you get on with them and then order some for myself. Thanks for guinea pigging it for me!
Posted: Thu Mar 26, 2015 7:43 pm
by darinz
I'm running rb25det coilpack in my vh45. Running wasted spark direct from autronic cdi so no ignitor at all. Coils are actually the same as vh45 just with different silicone. Tested silicone and swapped the good ones.
Posted: Thu Apr 16, 2015 8:27 pm
by Checkerhead
So how did these ignitors go? All installed and being thrashed by now I assume?
Posted: Sun Apr 19, 2015 6:26 pm
by 44jetboat
Nope arrived in country . Fitted up great . Mate who is wiring it up wants to do complete rewire . So wee way away yet. Will keep updated when this go move along
Posted: Tue Jun 16, 2015 1:41 pm
by Checkerhead
Do these coils fit underneath the covers that the factory ones go under?
