3.8l v6 rugger
3.8l v6 rugger
anyone ever put a v6 into a rugger? any tips? i got most the bits just got to put it in.
Re: 3.8l v6 rugger
have you done it yet, hows it going,any probs and what type of motor etc did you use?
cameronmaxwell@xtra.co.nz
0274202727
0274202727
Re: 3.8l v6 rugger
workin on it at mo just sortin bits and sortin rest of truck at mo. made into a ute aswell. tryed to put photos on but cant work out how. if some one can tell me i will. i usin 3.8 commadore motor and trans runnin into bighorn center dif
Re: 3.8l v6 rugger
to insert photos you 1st need an account with a site such as photobucket
you the upload the photos on to it and
some sites will have a thing under the pict saying
[IMG]http://i100.photobucket.com/albums/m16............. just an example
you copy and past that onto the page and presto you have uploaded an image
it needs to have that [IMG] bit in front of it or it wont work
i would highly suggest using http://photobucket.com/ as it is the most simple to use
0274202727
0274202727
Re: 3.8l v6 rugger
[img]http://s645.photobucket.com/albums/uu176/benorange/?action=view¤t=840A0227.jpg
Re: 3.8l v6 rugger
what i do wrong this all i got. will play with it later when get in from workin on truck
benorange wrote:[img]http://s645.photobucket.com/albums/uu176/benorange/?action=view¤t=840A0227.jpg
Re: 3.8l v6 rugger
just needs another [img] at the other end is all looking good though
0274202727
0274202727
Re: 3.8l v6 rugger
[img]http://s645.photobucket.com/albums/uu176/benorange/?action=view¤t=840A0257.jpg[img]
this it it at the moment it been on road but taking it back off this weekend ang will start on motor. the motor that is in it now is for sale.
Re: 3.8l v6 rugger
Re: 3.8l v6 rugger
Re: 3.8l v6 rugger
tack welded angle to the body and used a silacan glue that is made by simmons to stick panels on and seal around edges.
will be painting inside of deck with rino deck liner to help seal as well. still have a small leak somewhere but will find it.
sorry but the photos put me in a shed and i at home and can do most things but on a computer i realy sux. will try find someone to help me with photos as it should be good.
any adapters i need make i plan to make 2 and i 1 will sell if anyone interested
- Driver/Navigator
Re: 3.8l v6 rugger
Will you use the same transmission and transfer case? I don't think the stock transmission and transfer case can handle the power and torque of your V8.
Re: 3.8l v6 rugger
as at start i said v6 with auto trans.
the one that is in there prob would handle it if i wanter anyway. people do this mod with hiluxs and use hilux box and the rugger has more power than they do standerd
- Driver/Navigator
Re: 3.8l v6 rugger
My mistake. I sometimes confuse the rugger with a Feroza.
Good luck and keep us posted.
Re: 3.8l v6 rugger
got front off today and motor out it comes out easy as. rugger motor and box seams heaver than the one i putting in. will load photos at some stage
Re: 3.8l v6 rugger
yeh the motor and box out of those things are really heavy took me n me old man to lift a gear box and tcase into the back of me prado
0274202727
0274202727
Re: 3.8l v6 rugger
sat the v6 in place today. will have to lift body a bit or mod fir wall a bit i think to fit it in. will also have to mod sump and put it at the back of motor somehow. could b more work that i thought but all good that how it goes
Re: 3.8l v6 rugger
instead of moding the sump would it possibly be easier to make up a new one would it, probly have to extend the oil pick up lines to
0274202727
0274202727
Re: 3.8l v6 rugger
got all the truck striped now desided to paint it well i at it and build up a new wire loom and pull out air con box. pritty much get all the stuff out of it that dont need to b there or could cause probs.
i also lookin to change electric windows to man winders. does anyone know if rocky or fronza ones are the same or atleast b made to fit.
also want any info on on double u joints for driveshafts cos my driveshaft is going to be on big angle.
Re: 3.8l v6 rugger
motor mounts now made am bout to start or trans cross member and them hilux diffs.
does anyone have some i could buy. need to b off eary hilux
Re: 3.8l v6 rugger
sweet getting there slowly are you going to coil it or stay with the leaf springs?
0274202727
0274202727
Re: 3.8l v6 rugger
I regret to inform you that your not allowed to do this mod as I wanted to do it first and started before you. I am some what at a dissadvantage as you seem to have a shed n I dont. summer is here tho so things will start to progress.
I am mounting the rugger body on a prado coil suspension chassis. Puting a VN manual V6 to a prado 5speed. Locker in the back. hopefully a pto winch. She pretty much all mounted up, but a long way to go. Have sold 2 rugger gearboxs and believe they are weak so good thing your not going to use it. Keeping mine a wagon with a summer ute option as I prefer to have a dry storage area.
Re: 3.8l v6 rugger
what bit of it am i not aloud to do? as far as motor and trans goes i already talked to cert guy and he said it all sweet. and if it about the soa and using hilux diffs i dont c what the prob would b as the eary hilux front diff looks like it will just bolt strat in and back is only small mod. i leavinleaf spings in cos t much work to coil in a way that i can keep it on the road.
Re: 3.8l v6 rugger
sounds sweet like that then, id like to do what the above guy is doing but with a lexus or the 1kzte 3l deisel and onto the rugger chasis with a feroza cut into a single cab, probly would coil it and throw it on 80seris difs, very long term project lol
0274202727
0274202727
Re: 3.8l v6 rugger
I was just joking with you, as in I wanted to be the only one to have a V6 rugger. Im not trying to keep mine road legal, as I trailer it to save my mud tyres. Hlux diffs are the way to go, suggest you change the chassis spring mounts to match the hilux springs as they should be longer springs which will give better flex.. prviously did a SOA on rugger wasnt really happy with it. SOA turns in to about a 5-6 inch lift which for a narrow vehicle is a long way up. plus the misses needed a ladder
Re: 3.8l v6 rugger
2roky wrote:sounds sweet like that then, id like to do what the above guy is doing but with a lexus or the 1kzte 3l deisel and onto the rugger chasis with a feroza cut into a single cab, probly would coil it and throw it on 80seris difs, very long term project lol
lexus are a wide engine. ruggers are narrow engine bay. anything is possible tho. lexus engine are cheap but cost a fair bit to electricly sort out once in there. manual be tricky to. commodore v6 cheap easy to do and the next step would be a supercharged v6 engine which will be easy once a v6 has been in there. 80 serries diffs are heavy and expensive.
Re: 3.8l v6 rugger
wouldnt go changing the mounts would just make longer hangers, the problem with the hilux springs is that the centers are in the wrong places for the wheel arches, had that problem with mine,
but if you do use hilux springs then just make longer hangers as gives better down travel as with the longer hangers the sit at more of an angle which is where you get the travel
the pic kind of give an idea of how much flex with hilux springs (rears) and 3inch over standard hangers
yeh im really thinking of going with the 1kzte and auto more than anything as i like the drivability of the auto, im thinking 80seris as they are alot stronger than the hilux and will suit my application much better
0274202727
0274202727
Re: 3.8l v6 rugger
think i will stay with rugger springs and longer shackles and soa with hilux axles even though it will lift me 3'' on a narrow truck it will have a wider wheel base so should b all good. i have keeped motor lower than the stanard aswell to keep weight low.
as 4 you pruggerdore lol all good i was thinkin the same when i started mine but if yours is only off road that not so bad means less people will c it. lol
all i can say at this point to anyone thinkin bout doing this work to one of these is that it not as easy as doing it to a hilux. at mo i got frount axle that going to hit sump real bad and a front driveshaft that going to hit sump on auto trans. the soa should fix this i hope.
Users browsing this forum: No registered users and 27 guests
