Body Lift kits
Body Lift kits
Anyone know who sells 2 inch body lift kits for 1991 Feroza's, having a hard time finding any
Re: Body Lift kits
best bet is to find the materials and make your own.
why do you want to do a body lift that high? i used to run 31's on the standard height just had the rear springs reset with a bit more arch in them and the front torsion bars cranked a wee bit to level it out.
i wouldnt run tyres bigger than 31's due to the fact there is only just enough power to turn them even then its lacking a wee bit when you need it and they put alot of stress on your diffs.
iv'e been through 2 front diffs and one rear running 31's
cameronmaxwell@xtra.co.nz
0274202727
0274202727
Users browsing this forum: No registered users and 1 guest
